Question about Intel Desktop Board SE440BX-2 Motherboard
Board won't boot up.
Hello. My problem is that my board won't boot up. It is my evaluation that the bios somehow my be corrupted. I have removed all cards from the board except for video. The video card has been tested and does work. I have also replaced the microprocessor. It works too.
  • myvtv2 May 13, 2008
    The power light comes on but the board doesn't respond. I read an article which said that the SE440BX-2 model motherboards were shipped defectively. Apparently, there was a power supply issue with some of the boards which would send a signal that reset the bios or would wipe it out. It seems as if this is true.
    myvtv2
  • myvtv2 May 14, 2008
    I have replaced the CMOS battery. I have used two different power supplies (I am not sure what SMPS means). I have tried different memory. Nothing seems to power the board up. So what this tells me is that the bios is deprogrammed. The defect that Intel created with the power supply issue has wiped out this particular board. It was never sent back in for replacement of new capacitors and tested by the kit that Intel sent out to the manufacturers of the computers using these boards. So if I can't get the board to power up is there anyway that I can take it somewhere to get it powered up and reprogrammed? Or is it worth it?
Is there a place that can reprogram a dead motherboard? The hardware is good but the flash bios has been wiped out.
Posted on May 23, 2008
  • 48 Answers
Please tell if the power indicators are light up on CPU front and on Motherboard.. What happen when you press the power button... is there any beep...
Posted on May 13, 2008
  • Kapil Tiwari
    Kapil Tiwari May 14, 2008
    Check Power Supply (use another SMPS). Remove and re-install CMOS battery, RAM & Power Jack...
No video on dell inspiron mini
If it happened after the installation of Win 7, then board malfunction if not very likely. Do you get any video on start up. The Bios should be displayed fine as it is not related to Win 7 OS. However if no display during startup would mean somehow your BIOS got corrupted during the installation. Flashing the BIOS might help
Mar 07, 2012 | Dell Inspiron Mini 10 Notebook
Need BIOS Master password
you can remove this password by removing the bios battery. remove the cap where the ram goes... and you will have very easy access to the board. unplog the cable that goes from the bios battery to the board (make sure the pc is off and main battery is out.) plug back in the cable and boot your pc.
Feb 07, 2012 | Dell XPS M1330 Notebook
Hello. i have a problem whit my dell 1525 pp29l model.it wont boot up.when i press power button the power led stays on, and the scroll lock and numlock led flashes continuosly and nothing on the screen.i...
If it cannot finish POST then you have a mother board problem.
You state you reset the BIOS. Can you get to the BIOS menu? If you can then the problem is not motherboard errors but hard drive boot sector problems, depending on OS used.
If the BIOS has been updated, then it is possibly an incorrect version or corrupt.
If you can reflow the soldering, remove the BIOS chip and fit a known good one. That should fix your problem.
Hope this helps.
Nov 23, 2010 | Dell Inspiron 1525 Notebook
Intel SE7501BR2 cant get it to boot any os except ubuntu, curious that it boots and installs ubuntu have the drivers disk for the board but it wont boot tring to install winxp also it keeps giving me...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Sep 04, 2010 | Intel Server Board SE7501BR2 Motherboard
Comp. will not boot power supply is ok drives and fans run but no bios boot or any action?
Did you refash the bios?, you may have corrupted the bios rom chip. They can be bought online if you google your brand of board, ebay has a lot of that kind of thing. That's the cheapest fix that you can try, if you overclocked it or somehow it just fried the main processor, it could be dead, Also check to see if you lost a jumper off the board, your manual or online should have a schematic, and make sure your processor is seated properlly, it may just have popped out. Make sure the wires didn't fall off the start switch also. Just unplug it and open it up and recheck everything to see that it's all plugged in right. Sometimes a wire or jumper will just fall out, hope that's all it is
May 20, 2010 | Acer AOpen AX 59 Pro (91.87810.411)...
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
My bios is corrupted and iam not able to boot from it
I would only guess to reset CMOS and try updating BIOS from DOS. Altho, i couldn't remember for the life of it the process to update BIOS from DOS....sorry.
-Mike.
Jan 12, 2009 | Intel D845GVSR Motherboard
P5NT won't boot
Have you tried clearing the CMOS by removing the battery with PSU off and then shorting the 'reset cmos" (or similar) pins on mobo?
Also found this on the ASUS web site under the specs for the P5NT WS board...
01.gif ASUS CrashFree BIOS 2
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support DVD. Users can reboot their system through the support DVD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Have you tried this?
Jul 26, 2008 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Boot up problems
The beeps can be either video or memory. Most likely it is memory. Check the memory.
Thanks,
Lolita
Apr 09, 2008 | Mach Speed P4M800 (890552603480)...
Intel Desktop Board SE440BX-2 Motherboard Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
