Question about Altec Lansing BackBeat Plus Mobile Headset
The blue light stays on while charging after resetting the headset.
CHARGING HOW LONG
Blue Light staying on is a sign that it is in pairing mode. Depending on your headset the charging indicator is different. Consult your owners manual or http://www.motorola.com/support
Mark
Motorola Support
Jun 08, 2014 | Motorola Radio Communications
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Hi I have a samsung AATH200HBC bluetooth headset that was a gift and I've had it on charge for 24 hrs. Blue light is working but dont seem to be able to get any connection with it. Trying to pair it with...
this works with the Samsung range quite well also but you must get the sequence correct - phone blue tooth active BEFORE you turn on the headset then press and hold the on button until the blue light stays solid blue.
Jan 15, 2011 | Eforcity Samsung Bluetooth Headset WEP200...
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
How to reset a bluetooth
If you're resetting it one you're phone just delete the device in your bluetooth setting and set it up again. If trying to reset the bluetooth headset, hold the power button until the blue light stays on. That should do the trick.
Mar 16, 2009 | Motorola Mobility H350 Wireless Headset
Altec Lansing BackBeat Plus Mobile  Headset Logo
126 people viewed this question
Top Altec Lansing Radio Communications Experts
Michial Gueffroy
Jose Ma DM.
Jose Ma DM.
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
