Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Water doesn't drain from dishwasher - Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 07, 2010
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
I have a Magic Chef dishwasher that's between 10 and 15 yrs old. The dishwasher doesn't always completely drain and leaves varying amounts of water behind.
The drain pump may be faulty or the drain pipe exiting the machine is in the wrong position allowing drain water back into the system.
Hope this solves your problem
Aug 05, 2011 | Dishwashers
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Drain is plugged, leaking water
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Oct 20, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water does not drain out completely after cycling
Hi
Oct 20, 2010 | Whirlpool DU943PWK - Multiple Color...
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Oct 20, 2010 | Asko 1375 Dishwasher
Standing water in dishwasher
Hi
Oct 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Doesn;t drain water after wash
heatman101
Aug 29, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
74 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
