Question about GMC Vehicle Parts & Accessories
The unit sometimes locks itself when the keys are left in the car - to explain further when the car is in our garage we do not lock it ( our garage is locked) and leave the keys inside the vehicle but not in the ignition. As soon as the vehicle doors are closed the lights flash,the horn beeps and it locks it self.Why ?
    Top Expert:
  • GMC Master
  • 80,637 Answers
This is caused by the passive antitheft system, once u close the door is activated automatically, don't leave the keys in the car.
Posted on Sep 07, 2010
My passat central locking self locks when I leave the car
the security system is more than likely programmed to auto lock when ignition key removed and when door closed after you exit the car if you have a owners manual it should explain how to able/disable that function using the dash functions controls if that does not work you have a security system fault and you need to visit a vw garage good luck
Feb 03, 2017 | Cars & Trucks
How do you lock/unlock a sears craftsman 1/2 hp garage door opener wall control that has no lock/unlock button? The lights on the wall control are red and are usually green
On the door itself, there should be a silver cover over a key hole. You put the key in and the centre of the lock comes out and you pull the wire attached to the lock.
You can also try removing the batteries in the wall control and replace them with new ones.
Nov 24, 2016 | Building Materials
Model 3585 3/4 hp prof LM- today at 4pm all 3 remotes cause 2 flashes from garage unit and no action but does with wireless keypad and wired button. Did my remote programs get jammed? No lock option.
your lock is stuck on. Sometimes a unit will go into lock mode for some unknown reason. If you have a door bell switch for a wall switch then you have to go buy a multi function L/M wall control. They're not very expensive and are easy to install.
Nov 06, 2016 | Building Materials
Could you explain what the symbol of a closed padlock with the figure 1 beside it on the Touch Sensitive Control area indicates?
Hello Jack, I believe that the symbol means that your number lock is turned on. The way it got turned was at least two ways that I can think of. 1. The computer's BIOS is configured to turn it on when powered up. 2. You may have done this yourself by accident. The Num lock is also activated by a function key combination on the keyboard. To turn the lock on or off you locate the FN key at the bottom left side of your keyboard. Now on the top row of keys locate a shadowy outline of the words NUM LOCK. Press and hold the FN key and tap the NUM LOCK key. The light should go out. If there are further problems please return and post them here.
Nov 29, 2013 | HP EliteBook 6930p Notebook PC
Steering/brake is locked and key wont turn
Assuming the car is not running and you are trying to start it, sometimes the steering wheel is locked from the wheel thrying to turn back on itself and this won't allow the key to turn. Try turning the steering wheel all the way to the left or right then while the wheel turned, try to turn the key.
Oct 19, 2011 | 2003 Honda Accord
Garage door only opens from button inside garage not by bour remotes in our cars ( 2 remotes )
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN
Nov 13, 2010 | RTO Automatic Garage Door Closer
A 2002 ford Focus with the steer locked and can't start, tried turning the wheels to unlock but it still wont release. help Al
Use all the force you can muster to turn the wheel to the left while trying to turn the key. If that doesn't work, try doing the same thing, just turn it to the right. Sometimes the steering wheel lock pin can be stubborn. also **** it to the left and right really hard when trying the key. It also helps to pick the front of the car up with a jack when doing this.
Aug 15, 2010 | Ford Focus Cars & Trucks
I have a ford focus, when I press the fob the central locking locks & unlocks all in 1, I then tried to put the key in & lock it manually but it won't lock at all - any ideas, I can't lock the car...
hi this sounds like one of your locks has stuck inside the door, sometimes the locking mechanism gets stuck in the upright position and can not right itself, the only way you might be able to do it for a quick fix is remove the central locking fuse and lock it manually, try locking it from the opposite door that you can not turn the key in that should work, or manually lock the doors from the inside and then lock the last door with the key, then once you have done that try putting the fuse back in and then unlock it, if that does not work you might have to get a garage to remove the door panels and find out which lock is sticking...sorry its not much help but its something you can try.
Feb 19, 2010 | 2000 Ford Focus
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Light and lock buttons nonfunctional
There are certain models that had only a door bell type wall control and didn't have the lock and light functions. You may have one of these and someone has replaced the wall control with the three button model. If it did work in the past and has quit it is most certainly the logic board and is expensive to replace.
You say it is STILL stuck in the "lock" mode. If you cannot use your remotes you need to program it. Find the smart/learn button just to the left of all those white wires. Press and hold the button on a remote while you press and immediately release the smart/learn button. Do this for each remote.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Vehicle Parts & Accessories Logo
67 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
