Question about Dell AllinOne Multifunctional (v515w) InkJet Printer
ADF on dell V515w doesn't work. it was working well that it just stopped feeding the documents. the printer recognizes that a document is in the ADF, but it doesn't feed through to be scanned for anything--for copying or faxing...I need to place document on glass.
How can i get my printer to work
Posted on Dec 03, 2010
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Adf is not working
You might have paper stuck in the ADF. Check the ADF by doing the following: try using it for copies and see where it stops. If it stops at the very beginning it might mean bad feed rollers. Take out your feed rollers and clean them with rubbing alcohol and then dry them. If it stops deeper in the document feeder then there is either a paper clip or ripped paper blocking its path.
ADF AND COPIER PARTS AND SUPPLIES
Sep 13, 2012 | Office Equipment & Supplies
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Dell photo printer states: "clear ADF
Adf stands for automatic document feeder. It feeds the your original onto the scanning glass.
Apr 15, 2011 | Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
The paper will not feed to fax or copy on the top loader.
If your Dell 1815DN is jamming at Document Feeder (ADF assembly) the display may read Document Jam. You should replace the ADF Seperation Pad (Part# D1815-Z3) and the ADF Pickup Assembly (Part# D1815-Z4). Here is a video that shows you how. Iteminc.com has these parts and ships same day.
Jun 20, 2010 | Dell 1815dn All-In-One Laser Printer
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
May 29, 2009 | HP Officejet Pro L7650 Printer
ADF Does not show paper is loaded. If slide the document under the pickup roller in the ADF it will show document loaded but when I hit copy a "pickup roller error" is displayed. What would cuase...
Sometimes paper dust, and bits of paper clog the paper sensor, you can try using a can of compressed air to blow the sensor clear. use a flash light and locate the pickup rollers, and sensor. Clean both, if you can reach them. If they are clear, then the sensor might have stopped working. Check your warranty.
www.lhsjrinc.services.officelive.com
May 07, 2009 | HP LaserJet 3055 All-In-One Printer
Dell AllinOne Multifunctional (v515w) InkJet Printer Logo
419 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
