Dell Vostro 1510 Laptop Logo
Posted on Sep 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After turning on the computer the screen remains black and all I see is a small blinking lock with a 9 inside. Is there anything I can do to solve this problem
Anonymous
Level 3:
Guru:
  • Master 689 Answers
  • Posted on Sep 07, 2010
Anonymous
Master
Level 3:
Guru:
Answers
689
Questions
Helped
131337
Points
1793
Sounds like you need to enter a code or password unless its for a different overseas market--lobby support line with serial number,,they might be able to tell you market ect
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
1helpful
2answers
My HP pavilion DV4 will turn on but not display anything. The screen remains black and the caps light/scroll lock buttons blink. Trying to figure out what it is if you can help please respond.
AC adapter (Charger) removed from the laptop, remove the Battery. Wait 1 minute then reinstall the Battery.
Post your findings in a Comment.
Regards,
joecoolvette
1helpful
2answers
2answers
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
1helpful
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Blank screen. Remains blank
Power down, remove the battery, remove the power plug. Hold down the power button for at least 30 seconds. Remove and reinstall the memory module(s). Re install the power plug and try to power back up and see if it works. If it does, reinstall the battery ad you're done. If not, get back to me for some more ideas and further diagnosis.
Thanks and have a good day!
Ron
Screen blinking
flash u r phone with software before flashing change display socket witch is on board u rproblem will solve send me u r rply on [email protected]
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
