Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months ago with no problem. Any ideas if this is a quick fix....or a TV on it's last leg?
No solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Posted on Sep 21, 2010
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Vertical blue lines appeared on the screen with no sound.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Jun 07, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
Apr 03, 2010 | Samsung HL-R5656W 56" DLP HDTV
Vertical lines appear on the screen.
It appears like there is a bad capacitor in the horizontal circuit. Try to put a fan near the ventilation trap, just for a test.
the part cost almost nothing but having someone to your house is expensive.
Your decision.
Jul 01, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
RCA DLP/HDTV Vertical Lines
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Dec 19, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
186 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
