Question about Protron PLTV-32 Television
No prower to tv plug and outlet OK - Protron PLTV-32 Television
  • 11,361 Answers
PLTV-32 uses AC adapter tah puts oit 12 and 24vdc, the PLTV-32C uses internal power supply. You need to check the DC output of the AC adapter or go in side to check the power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 07, 2010
Craig tv plugged in stand by light won't come on and tv won't play
It could be. But make sure the power outlet is ok. Please try on a different power outlet.
Aug 25, 2012 | Televison & Video
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Good day! We were watching TV when suddenly lightning occurred and our TV also turned off.What is wrong with this?
will tv turn back on. if not then it was sturck by lightning. i found that it does not have to hit directly.it can be caused by a power serge. witch means repair costs. when you get it fixed you need to by a power surge prower cord and plug your tv into it an all other things you don't won't sturck.
Aug 18, 2011 | JVC AV32F476 32" TV
My DYNEX 19" LCD TV dont turn on?
Power at the outlet? ok?
Plugged in the outlet? ok?
Power cord plugged in to the REAR of the tv very snug? ok?
Using the remote? Batteries ok? ok?
Red light on? ok---- Unplug the tv for a few seconds and retry. ok? Still no-go?
Unplug the tv and remove the rear cover, remove the stand screws to do this. ok?
The small circuit board ( you will be certain you have the correct board simply because it is the smaller of the two boards. The Mother board is much larger. Another way to be sure you have the correct board is to folow where the power cord connects to the tv----that board!!! )ok?
Now, very important!
There are small components called CAPACITORS. They are approx. 1/2 inch high and about the size of your pinky finger around. They all look about the same, but vary in size. They will have an "X" marked on the top usually. Now, this is what to look for! They must be FLAT on top. If they are round, buldging, or burnt then they are BAD!!! Take care and you can easily remove the board by simply removing the wires and screws from the board. (be sure to draw on paper where things go or otherwise mark where they go so reinstalling the board will be rather easy)
Remove any glue from them carefully and then using a soldering iron or gun just simply melt the solder on the rear of the board and pull them out. Take them with you to your local electric supply store and solder in the new ones. Look for any bad ones on the MOTHER board also and replace if needed. Rarely are they bad. The problem is nearly always with the POWER board.
With everything hooked back up and put back together, plug the tv in to the outlet and turn on the tv. Voila, enjoy!
NOT willing to do this. Well, simply get the model number, etc., and google the power supply for it and order it. Install it, trust me you CAN do this, and There you go. Enjoy!!!
Mar 24, 2011 | Dynex DX-LCD19-09 19 in. LCD TV
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Gets hot when drive it sometimes and loses prower then it will be ok
This problem sounds like you may need the catalytic converter replaced or a piece of the converter has broken off from inside and is plugging the exhaust off further down the system,usually at the front of the muffler.This will cause the truck to lack power and you will find it is burning more fuel then normal,and also can cause overheating.
Mar 18, 2010 | 1998 Ford Expedition
Tv won't turn on
check one by one :
1. power in outlet by plugging an other equipment in the outlet used for your TV,
if ok try #2
#2: carefully open the back and check the power cable with ohmmeter
if ok , try #3
#3. check for the fuse ,
if ok , call a technician because there is some fault which you can't do by yourself
Sep 14, 2009 | Televison & Video
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Our Syvania tv just stopped working. No sound, nothing. We checked the elctrical cords, and remote etc. It will not turn or click on at all.
You may have a blown fuse inside the TV. Also make sure your AC outlet is working by plugging in another lamp to the same outlet.
If your outlet is ok, your TV needs service and repair.
Feb 24, 2008 | Televison & Video
Protron PLTV-32 Television Logo
89 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
