Question about Kenmore Elite HE4 Electric Dryer
Pressed buttons on dryer and is totally dead even the inside light is not functioning, checked circuit breaker and tested outlet with an olm reader and there is power in the plug. What could the problem be?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
Fix aeg t35850 dryer
How can it be totally dead? Is the dryer still getting power? Check circuit breaker. Sometimes those breaker units just get old and do not hold and will pop off.
Nov 23, 2013 | Dryers
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
I have a kenmore Elite dryer it was working fine than blew the circuit breaker, I unpluged it reset the breaker pluged it back it and it sparked and blew the breaker again. I disconnect the motor in the...
If the dryer is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. or a wire is loose to breaker.
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the dryer is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. check outlet to find out !
Mar 29, 2012 | Dryers
Dryer was working fine until I turned off the breaker to work on an electrical outlet on the same circuit. When I was done I turned on the breaker all other outlets worked, I went to use the dryer and...
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
Jul 29, 2011 | Estate TEDS840JQ Electric Dryer
Lead display is keep on flashing up on start sequence
Have you tried checking the fuse or the circuit breaker? Are both the washer and dryersharing the same two outlet duplex outlet or are they on two totally separate outlets? Just to eliminate/isolate the outlet question after you check the circuit breakers or fuses in your fuse box, try plugging the dryer into a separate outlet. If like many people you do not have an extra outlet in your laundry area, try plugging another item into the dryer outlet to check it for power. This is if you are talking about a gas dryer that works on a 120-volt electrical outlet. If it is an electric dryer it will be on a 230-240 volt outlet with a special plug. If you have an old circuit panel that is still using fuses as opposed to modern circuit breakers and if this Is an electric dryer, you would have a 240 volt disconnect plug more than likely inside the panel and if you firmly grab the handle and yank it straight out, you will see that the disconnect plug will have two short cigar shaped Buss Fuses in it. If this is the case one or more of those fuses could be blown. Depending on the electrical requirements of the dryer those two fuses amy need to be between 20-30Amp rated. or else if you have the manual take a look in it , perhaps one of the fuses is gone .
Apr 30, 2011 | Washing Machines
All circuit breakers good in box. have no power to 3 rooms on outlets or lights . problem started when using a hair dryer hooked too a drop cord in a outlet
the first thing that I would check is to see if there is a GFI outlet inline with the other outlets that are not working,, if there is one then check to see if you can reset it using the little reset button -- if by using the reset button does not fix this problem then there is the chance that the GFI outlet is bad and needs to be replaced. the next thing that comes to mind is that you said the breakers in the box are good, but I have seen sometimes where you need to flip the breaker totally off and then back on and this could reset the breaker. if you are still having troubles then the problem could be that one of the outlets in line has gone bad and needs to be replaced or the breaker in the box could also be bad ( use a meter to check that you have power on the output side of the breaker and trace from there from outlet to outlet until you find the bad one ) ---- could also be just a bad wire and while testing with your meter you should find it as you test the wires to the outlets.
c...
Jan 23, 2011 | Electric Drill Scaler
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
Normally pump motors are connected on a separate
circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
circuit breaker (biggest amp rating).
After resetting the circuit breakers, try to switch your
bathtub pump on, (to test it, if it is still okey). Other-
wise, your motor is damaged and you got to have the
motor rewinded, to be operational.
Dec 09, 2009 | Plumbing
Kenmore Elite HE4 Electric Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
