Question about Bose Lifestyle 28 System
Unable to get video signal connected properly
    Genius:
  • 1,622 Answers
Make sure your playback devices are properly connected to your receiver. Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver. DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs. Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component. If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV. If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system. Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television. If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote. When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
5
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable. Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Hope this help in solving the problem,Thanks and take care...
Posted on Sep 07, 2010
No signal detected message on monitor, cpu and monitor are on
Good Day Jboone563!
You need to check if the VGA cable is properly fix to the monitor and video card. Loosen connection or no contacts is the reason for the "no signal" display on your monitor.
This means that there is no signal coming out from the video card, going in to your monitor. If by fixing the VGA connection did not fix it, try removing the video card from the motherboard and then reseat it properly to the motherboard slot.
If this do not resolve the problem, Jboone563, I'm sorry but you will need to replace the video card.
May 26, 2011 | AOpen 19" LCD
No signal but sound is on
Depending on how you have the TV connected the audio signal wiring can be seperate from the video signal wiring.
You most likely have an HD Television:
-If you are using DVI, make sure that it is properly connected by unplugging then replugging it back in.
-If you are using Composite cables (The Red, Blue, and Green plugs) make sure those are in and that the Red and White cables are in their proper areas too.
-HDMI connections have carries both video and audio, so if you have this then unplug and replug it in.
Feb 28, 2011 | LG Televison & Video
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
Hi, This is Aktar Alam from ADA Aurad I am unable ...
Your Video Controller PCB Assy is not functioning properly. You'll need to get replacement. And check you power cable is the earth connection connected. If earth connection not connected properly, always causing this problem.
May 21, 2010 | Canon LASER SHOT LBP-2900 Printer
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
HP compaq nc 6000
jdawg01,
the signal that receives by ur adapter is not that much strong so it was unable to connect properly..u might have receive a low signal..
Apr 06, 2008 | Computers & Internet
Unable to connect vdr-d250 to pc
I think that the following are to be taken care of first:
1.Cam corder to pc cable is properly connected.Some call it as 1384 connection also.
2.Cam corder should also be run on play mode for transmitting a/v signals to pc to decipher.
3.Ur pc also should have been installed with codec for processing the signals .
4.Your pc also should be usb.2.0 capable.
5.The media on the cam should not be protected for free playing along with pc.
If all the above are checked you would have cracked clear right.
good luck.
Feb 05, 2008 | Panasonic VDR-D250 DVD Camcorder
Bose Lifestyle 28 System Logo
83 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
