Question about Frigidaire ATF6000ES Front Load Washer
The washer will not spin. I have changed out the control board and it still will not spin.
  • 10,319 Answers
Many reasons for this so read up on this website below
http://www.repairclinic.com/Washing-Machine-Troubleshooting
Posted on Sep 07, 2010
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: Change motor and motor control board
you mean it doesnt spin , but does it goes thru the wash cycle?? if yes , then its not the main motor thats defective,it could be the DRAIN MOTOR PUMP ,COULD BE CLOGGED
Posted on May 19, 2008
  • 62 Answers
SOURCE: Washer will not spin dry. Control Board seems to be the problem. Please advise
ck water pump, but that sounds like a board
Posted on Oct 22, 2008
  • 10 Answers
SOURCE: front load washer wont spin
I have a Frigidaire Affinity and the same thing happened to me. After looking on this website I found someone who told me to change the door latch assembly. I went to my local parts supplier and bought a new door latch assembly for $53. My husband replaced the door latch, and it works like new! The good news is the replacement part is better made than the original. The parts guy said he's never seen one fail a 2nd time. This is a cheap fix to a serious problem.
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: my kenmore washer will not spin model number
No that will not solve your problem. The ctrl board isn't reading movement from the motor. Replace the motor only. maytagplb@yahoo.com
Posted on Sep 19, 2010
My ATF6000ES Front Loading washer runs on any cycle for about 5 minutes then stops, and the display resets to the start and nothing more happens. Got an E48 code and ran "test 7" and the tub did not
Hello Nick Jensen, thanks for your post!
From what you have described your Frigidaire washer is displaying an error code of "E48" and you have changed the control board with the problem continuing to be present. An "E48" error code could be a possible problem with your door lock assembly, motor control board, or control panel. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. I hope this is helpful. -Matt
Jan 30, 2015 | Frigidaire Affinity ATF6000F Front Load...
Not spinning
Its likely you need a new motor speed control board, its the most commonly replaced board in these washers.On this model its located underneath on the right or left wall.You can't really test this but try putting the washer in to the Spin and Rinse cycle, if it doesn't spin then that is most likely your trouble.I did a quick Google search and found this page for the part:http://www.appliancepartspros.com/frigidaire-control-board-134743500-ap3891780.html
Feb 19, 2013 | Frigidaire GLTF2940FS 3.5 Cu. Ft. Front...
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Is the washer worth fixing? My washer stopped
Without looking at unit would most likely be door latchlock or motor control board that is the board that is located at bottom of unit under tub/if someone told you it needed more than one board that is highly onlikely/don't think i every changed more than one board at a time. Questions czerney@msn.com
Oct 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not go into high speed spin
could be door switch if machine control bd does not sense door locked will never go to spin also could be main control under console look for scorched or burnt componets on bd
Dec 16, 2008 | Maytag Neptune Washer
May 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin
Is the lock door light on if not change the wax motor & the main control board (board is approx $169.00+).That is the problem unless the belt slipped off .Common neptune issue you have will most likely repeat itself so,you decide from there.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
