Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Have a B&S, Vanguard, 23HP motor, model 386777 with 300hrs on it. Motor starts and runs fairly well, but a fair amount of smoke is being emitted from air intake. Very evident with air cleaner removed. For the most part, smoke is whitish, not black. Checked compression. It appears 1 cylinder is getting 150, the other 90psi. Due to contortions required, may be some inaccuracy related to poor checker seal at plug hole. It seems as though the plug with the higher compression is burning richer than the one with the lower number. That is, one plug is a fair amount blacker than the other. After starting, engine has a lopping/uneven idle that clears up after a minute or so. It appears that an automated arm beneath the air intake is actually adjusting the idle. You can see it move up and down as the idle varies. Any ideas as to the reason for smoking, etc.? Thanks.
Sounds like you have a bad set of rings on one cylinder,or a bad valve set.
the stronger compression cylinder will burn richer due to the fact that the lower compression cylinder isnt pulling a hard enough vacumme to draw in all the fuel that is dumped into the intake.when the good cylinder makes it intake stroke it pulls in the excess fuel and a fresh amount from the carb.
im leaning more towards the valve train on the bad cylinder due to the white smoke comming from the carb,if the intake valve isnt seating properly,you will have compression escaping,back feeding through the intake.but yoy should hear a popping along with the smoke,everytime the engine fires that cylinder.
hope this info helps you.
4 stroke
#1 intake stroke
exhaust valve closed,intake valve open.as the piston is on its way to the bottom of the bore,it creates a vacumme.drawing in the air/fuel mixture from the carb.when the piston hits the bottom of its downward travel,the intake valve closes,then the next stroke comes into play.
#2 compression stroke
after drawing in the air fuel mixture,the intake and exhaust valve are both closed.the rotating momentium pushes the piston back up the cylinder,compressing the air/fuel into the cylinder.
#3 power stroke
(depending on the timing)when the cylinder reaches top dead center (tdc)in the bore.the spark plug ignites the fuel,which causes the air/fuel mix explode.that explosion forces the piston back down into the bore.when the piston travels down,this stroke is completed.
#4 exhaust stroke
after the power stroke,the piston then travels back up the bore,while opening the exhaust valve.the moving pistion then pushes the exhausted air through the exhaust chamber and out the muffler.
then the cycle starts over again.
so if you have a valve thats not seating properly,on compression stroke you will have loss of compression,on the power stroke,loss of power....forcing that ignited fuel back through the valve that isnt seated corectly(if intake) you will get white smoke and a poping sound from the carb.on the exhaust stroke it will sent exhausted air back through the intake aswell.
once again i hope this helps,id dig into the valve train on that cylinder.
nick
Posted on Oct 25, 2010
My 23hp Vanguard motor stalls every so often, To restart it I have to turn the battery isolator switch off then back on again before it will restart. could it be to do with the oil pressure switch
stalling
yes oil pressure switch's /modules are wired in to the spark systems of small plant motors as motor protection
i cant see one listed as a part for sale for 23 hp vanguard briggs
or mentioned in the user manual
386447 3079
if oil level is ok and oil pressure switch isnt the problem
check the governor adjustment
or adjust the idle
very simplistic drawing
386447 3079
Oct 20, 2016 | HP Tools & Hardware - Others
I have a 90 series washer and I just changed the motor coupler. Now the washer emits a electrical burning smell. what can I do?
not proper fitting has been done so motor is jammed,,,not moved freely so the burning smell is from motor ,,,disamble & assemble properly,,,check brakes fitting also due to jammed motor
Mar 11, 2015 | Kenmore Washing Machines
How do I test alternator on 23hp Briggs & Stratton vanguard mod. 386447
Please make sure you turn off light switch after cuttings or start up
Feb 02, 2015 | Tools & Hardware - Others
15hp Briggs Vanguard 1cylinder runs like it's on choke emitting black smoke. What can be wrong ?
The "black" smoke has me wondering... I would suspect that you may have a broken ring on the piston, or even ha hole in the piston.
Several weeks ago I found two of my neighbors mowing lawn and pumping out heavy clouds of smoke. I went to each of them and they told me they just filled the oil. They filled it up until it came out of the dipstick hole. This results in too much oil in the crank case and not enough air, so the engine forces the oil past the rings and then you are burning oil with the gas producing a large amount of smoke. I took my turkey baster and a can to each and removed the oil until it was at the proper level. Then I showed them the dip stick and explained that the oil level must be between the two marks on the dip stick. This situation of too much oil produced a huge amount of smoke, but the smoke was more white than black.
- Joe
May 11, 2014 | Tools & Hardware - Others
Power mate brush motor not coming on and overload rest not doing anything
I don't believe that there's any penalty for using the proper amount of words to give us a fair idea of what's going on or not, with your machine." Power mate brush motor not coming on" only gives us a bare minimum of info. Does the vac motor run alone, does it still run when you slide the selector to vac & P.M. or does it quit, have you tried pushing the little red reset button down?
Oct 22, 2013 | Kenmore Sears electric vacuum hose models...
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Emits white smoke
Blown motor. Replace motor. Check Harbor Freight. Bolt mounting pattern critical as well as shaft diameter and length. Northern Tool can supply most motors. You need model no. of motor.
May 26, 2013 | Garden
Husky Compressor Model WL660800AJ, S/N L8/4/04-00830 started, filled tank, cut off and now will not restart. I turned the reset switch to off overnight, but still will not start this morning. Power is...
All electric motor compressors have a reset switch somewhere on them, usually on the motor itself. Look for a small, usually white button, sometimes with a number on it. If its tripped the button will stick out, push it in to reset it.
Air compressors need a fair amount of amps to run and the requirement rises as the tank fill because the motor is working against the pressure in the tank. A rule of thumb is: always run longer air lines, NEVER use extension cords. If it is absolutely necessary to run an extension cord, make sure it's a 12 guage cord or larger, no more than 50 feet long.
Jan 05, 2011 | Garden
24horse vtwin runs good at half throttle seems to lack power.turn on the mower deck and sometimes it runs ok but will not mow normal lenth grass not much power.if i turn the throttle up wide open it will...
Sounds like you're getting enough fuel (black smoke) Could be running on only one cylinder. Either stuck valve or loose valve adjustment or one bad magneto. You could try starting with one spark plug disconnected. If it doesn't start, reconnect that one and disconnect the other. IF it runs like it was, then you're running only one cylinder, and go to work on finding out why.
Aug 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
91 kx 250 blows smoke and drips alot of unburnt oil out the pipe
Does it have a stock pipe,carb,any modifications! If its stock,I would put a new ring and piston in it,it seems like your getting a lot of blowby,also make sure your air filter is clean. It would help if you used an iridium spark plug.
Jan 21, 2009 | kawasaki KX 250 Motorcycles
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,558 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
