Question about Acer Aspire 5002WLMi Notebook
Dim Screen When I turn on my grandmothers Acer it starts up like it is suppose to.  However the screen is very dark and you need to hold it just in the right light to be able to see the screen.
  • yanksguy Nov 10, 2008
    I also have the dim screen. I have the Acer aspire 5050 and it has gone dim. For awhile there I could move the cover back and forth and find a spot that kept it bright, but no more. I haven't even used this laptop that much and have never dropped or banged it.
    I've tried the Fn/arrow key but that doesn't work. Any other ideas?
    I'm about to send it back as this is killing my eyes!
  • Anonymous Nov 17, 2008
    Yes, I did have the same problem - and it WAS the function/arrow key that solved it: THANK YOU!
    Genius:
  • 3,587 Answers
There is a monitor brightness that is usually a combination of Fn(lower left of keyboard) and F5..try that to see it it raises the level
Posted on May 13, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Hasn't been used for a while and now won't turn on...changed batteries
Very likely that the screen contrast changed after the replacement of batteries.Some times screen becomes too dark or too dim.
If it does not seem to turn ON that may be because screen is too dim that you cannot see anything and cannot be sure it is ON.
To darken the screen:
  1. Press the ON button
  2. Press [2nd] key and release it.
  3. Press and HOLD the Up Arrow.
  4. Keep at it until screen starts showing something.
Jun 24, 2010 | Texas Instruments TI-84 Plus Calculator
The laptop screen turned a funny orange color on start up and then the screen went dark. Pressing the brightness buttons has no affect. Any quick fix?
Check it on an external monitor to see if the video card is good. If the external works, then the LCD or backlight is bad. Look with a flashlight. If there is a very dim image, then it is probably the backlight. If no image, then the LCD.
Apr 20, 2010 | Acer Aspire 5100 Notebook
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 07, 2009 | Acer Aspire 5040 Notebook
Acer Laptop Dark Screen
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Acer Aspire 3680 Laptop
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
VERY DARK Screen (more info inside)
hiiii ther
how r u ??
yeah ur back light is not working propley
u need to chick teh hardwear
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 20, 2008 | Acer Aspire 3690-2196 Notebook
Acer aspire 5043wlmi laptop starts but know function of lcd but works on desktop monitor
The computer's power management system automatically dims the screen when using battery power, which is one of the power-saving features.
To adjust the brightness:
  • Hold down the Fn Key located at bottom left of your keyboard next to the Ctrl key, and adjust the screen brightness using the left/right arrow keys located at the bottom right of the keyboard.
If that's not it then
A dim or dark screen does not necessarily mean a bad inverter! It could be a faulty lcd backlight bulb, inverter cable, inverter, or in some cases a motherboard failure. If your still under warranty then I would get Acer support on the phone and see what they can do.
An Inverter converts direct current (DC) to alternating current (AC).
Jul 01, 2008 | Acer Computers & Internet
Acer Aspire 5002WLMi Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
