Question about Kenmore Elite HE4 Electric Dryer
The dryer runs bt will no longer produce heat, also when I open the door it stops tumbling and restarts tumbling as soon as I close the door?
  • 10,319 Answers
The dryer starts with a sound you can hear which is a clicking sound. That will be the ignitor lighting up the burner. If not hear replace the ignitor. If heard clicking the moister sensor can be at fault or the exhaust vent tubing is full of lint. The moister sensor detects lint and will put the heat into check. Also your switch mounted by the door needs replacing. It does not work as it should no longer if the dryer starts up upon closing the door
Posted on Sep 07, 2010
My dryer heats,tumbles, drys,but will not stop running. model fdr336res2.
The door switch is likely stuck closed. Free up the switch inside the door by hand and replace if necessary.
Feb 11, 2017 | Dryers
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryer will not tumble
HI your right on the money , it is the belt. replace thanks.
Oct 11, 2008 | Maytag PYE4557A Dryer
When you open the door to check if the clothes are dry, the dryer keeps tumbling even with the door open.
This is commonly caused by a door switch that is shorted. The switch is located in the door frame opening and is activated (or closed) by a push button when the door is closed. This will enable the drive motor and heating circuits when the start button is pushed. When the door is opened, the switch no longer makes contact and the drive motor and heating circuits shut off. I would recommend checking to see if the push button the switch is just stuck (pushed in). You may have to replace the switch to correct the problem. If you would post your COMPLETE model number (located somewhere around the door opening) I can look to see how this switch is installed and any parts necessary to replace it. i hope this helps you.
Sep 28, 2008 | Roper Dryers
Kenmore Elite HE4 Electric Dryer Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
