Question about Kenmore 88732 Top Load Stacked Washer / Dryer
I have the 26-88732 washer - dryer Is it possible to change wiring so that the 110 v units will run at the same time Now I have to do a load of wash and then dry - I would like to do a loAD OF WASH WHILE DRING A LOAD OF CLOTHS. mitchmitchell47@hotmail.com
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 117 Answers
SOURCE: kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Washer_tech
  • 164 Answers
SOURCE: Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Posted on Mar 31, 2009
rylee_smith
  • 8619 Answers
SOURCE: Washing machine is not spining
Hi
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 Series Model 110-25862 that won't start wash cycle
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
This is a very simple and inexpensive repair that you can do without the assistance of a repairman. The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949238.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Posted on Mar 19, 2010
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
Bloody washer dryer Hotpoint wd420p 606200214
at what point is that getting heated up actually?
Jan 22, 2008 | Washing Machines
Washer won't turn on unless dryer is on
I assume you have a gas dryer, as a washing machine runs on 110 Amps while an electric dryer uses a higher 220 Amps. If both the washer and the dryer cords are plugged into the same socket, and the washer only runs while the dryer is on, the socket is not wired properly. You may check this easily enough by switching the washer cord to the one presently utilized by the dryer. If the washer runs, then look at the wiring.
Mar 04, 2015 | Washing Machines
Does this combination unit need both a 220 volt for the dryer and a 110 volt for the washer?
yes in that way work. Is o.k the power for dryer will be more strong that the washer, The reason is heating elements fro dryers.
God bless you
Sep 28, 2012 | Whirlpool LTE5243D Top Load Stacked...
Hello.. I have a 220v stack washer and dryer unit. I live in hawaii and never use the dryer and electricity here is at a premium. I would like to run just the washer on 110 and disconnect the dryer and run...
Hello Troy, I have checked the schematic which should be located behind the sloping front panel above the washer lid. The washer portion is powered by 110 vac supplied from the dryer's L1 connection (black) and the neutral (white). It should be quite simple to make an adapter with "hardware store" parts like a standard 20 amp plug and an appropriate 220 volt receptical. Please verify that the neutral lead goes to chassis ground and make use of the 110 plug's ground to the receptacal ground (green headed screws) with a seperate lead, for your safety. When the machine is plugged into the adapter, only the washer should function.
As a final note, I see that the dryer motor and timer are also 110 volt but are connected from the other hot lead, L2, to neutral. Only the heater is powered by 220 vac. Therefore if you should connect to L2 by mistake, only the dryer drum would operate. Unfortunately, I do not see a simple way to make both the washer and dryer run on a single 110 feed.
Jun 04, 2012 | Kenmore 94812 Top Load Stacked Washer /...
I bought a used stacked washer /dryer. I hooked it up likea standard 220 dryer. Has the standard dryer plug in. Would not run start or hum in 20 mode. Checked the wiring. looks like it was wired for 110,...
All standard dryer motors run on 120V. Its the heater that uses 240. Its possible to wire a dryer for 120V operation and it will appear to run ok but it won't heat efficiently and it will take several cycles to get the clothes dry. Sounds like you have a mechanical problem with the motor.
Jul 14, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Frigidaire Laundry center blows circuit when w/d run at same time
Okay, here's the best I can do from this distance.
The combo unit is on a 30-amp, 220-volt circuit. One cord supplies both washer and dryer.
The breaker does not trip until the washer motor starts running simultaneous with the dryer drying.
My guess is that (if the combo unit is connected correclty to the one supply cord) the dryer motor runs off the 110 volt supplied by the red/white wires & the washer motor runs off the other 110 volt leg, black/white (could be vice-versa, but that's irrelevant).
The dryer heating element runs off the 220 volt supplied by the red/black wires.
There are two most likely causes (but not the only possibilities):
- The breaker is bad -- could just be oxidation on the breaker contacts in the bteaker box -- I havae seen this conditon -- small amounts of oxidation can cause the breaker to overheat and trip -- of course, the more current the load draws the hotter the breaker gets.
- One of the motors (washer or dryer) is beginnig to fail (windings beginning to short) and drawing more than rated current which is overloading the breaker.
Checking thes two theories requires some not-so-standard equipment, and some more-than-handyman expertise. And if neither of these theories pans out, the troubleshooting gets more complicated.
So, to address your original question, "Can I fix it myself, or should I hire someone?, I would say you should hire someone. This wirite-up may give them a head start.
Let me know if you have any questions.
Charlie
P.S.
A third possibility (only possible if this tripping condition ahs existed from the beginnig of the w/d installation) is that the power cord is connected to the unit such that both motors are powered by the same 110 volt leg. Not being there to assess this, I can't say how likely this is, but it's a long shot for sure.
May 27, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
No Power
yes
go to your fuse box if 220 flip both switches if fuse engaged there will be like a red line or fully difused down to show that fuses has been triped
if 110 your going to be flipping switches alot cause 110 runs both motor and guages together and over power is usually the cause of this
220 circuit one 110 runs the guages and the other 110 runs the motor and heater core
also washer wont run with out the water being on saftey feature
Nov 12, 2007 | Maytag LSE7806A Top Load Stacked...
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
