Question about Canon PIXMA MX310 All-In-One Printer
Put new ink cartridge and error message of U059
SOURCE: Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Put a piece of masking tape on the sides of the little window on the cartridge. That will make the machine think all cartridges are full all the time.
Posted on Mar 14, 2008
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
realbat2
  • 68 Answers
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
Posted on May 26, 2009
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
SOURCE: Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
Posted on Jun 16, 2009
Refilled the ink cartridges and now get error message U059 check col ink. I've cleaned all the contact points, any thoughts on how to reset the printer to recognize the cartridge?
Refilled cartridges give a lot of trouble , I only use genuine. click start, devices and printers , right click the printer image, click trouble shooter follow instructions. Don't be supprised if the only fix is a new cartridge.
Jun 11, 2015 | Canon Pixma MX410 All-In-One Printer
Check Ink error U059
Canons definition of U059 is:
"The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge. If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative."
In my experience this is normally due to dirty or damaged contacts on the cartridge. I would recommend wiping the contacts on the cartridge with a piece of kitchen tissue and trying again. if this doesn't help try simply replacing the cartridge.
If the error persists try cleaning the corresponding contacts inside the printer in case they have become dirty/oxidised.
Oct 17, 2012 | Canon PIXMA MX310 All-In-One Printer
How to make Canon pixma MP-220 to recognise refilled ink.
Read the manual.
Get online and got to www.google.com In the google search box type: "Canon Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals on the site.
An Error Message Is Displayed on the LCD (MP220 series)
Message
Action
CHECK INK
U051/U052/U053/U059
Jun 02, 2012 | Office Equipment & Supplies
My canon PIXMA MP450 all-in-on-printer is showing U059 the following ink cartridge cannot be recognized i tryed to put the old ink tank in but it said the same thing
Basically, there is no solution for your case. This happens especially for Canon product.(called e5 error) Once a cartridge is not recognizable, there is no way, you can use it.
The only way you can do is, replace with brand new one. This is typical Canon problem especially when you refill or re-use your cartridges.
You may see some solution from web such as reset the printer, do somthing to printer software... But non of these methods are working.. Even if there is one, it must be very difficult to do it for individual users.
However, as for a prevention, make sure unplug the power cords before insert or eject the cartridge from printer. In that way, you can at least reuse your cartridges for refill. Hope it helps.
Dec 13, 2011 | Canon PIXMA MX310 All-In-One Printer
Hello.i have a canon mx 300.i have changed both ink carts[properly] and it reads"U059 check ink col".any suggestions?thanks...
check that the tape that coverd contacts has been fully removed and that there is no residue on either the cartridges or the receptacle the error points to the color cartridge, it has happened to me previously were a cartridge is bad out of the box and needs to be replaced.
Jun 20, 2010 | Office Equipment & Supplies
When I put in new colour cartridge 41 into my MP170 printer error message U059 appears. I have tried 3 new cartridges with same message appearing. When I replace it with old cartridge the message...
Hi ther
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 16, 2010 | Canon PIXMA MP170 All-In-One InkJet...
MP 170 check ink
U051,U052,U053,U059 all are signal or Error is mean CHECK CARTRIDGE
The Fine cartridge may not be install properly,or the cartridge may not be the compatible with this machine.Install and appropriate the fine cartridge.
Dec 03, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
May 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
133 people viewed this question
old marine
old marine
