Question about Dometic Rooftop RV Air Conditioner
I have two Dometic roof top units both have sepreated controlls. The smaller bedroom unite will not shout off. When turned to off, when the thermostate is lowered, or when the controll is switched to furnace. Still the unite will keep running. The fan can be low or high but the unite will not shout off unless the breaker is opened. I thought the problem may be the wall mounted controll so I switched the one from the front (knowened to be good) to the back bedroom. No change. The bedroom controll works all the functions on the front united as desinged. The bedroom AC will still not shout off, Please advise "Thank You" Mark. Mathertulip@comcast.net
    President:
  • 3,074 Answers
May be the relay is stuck, you will need to open the unit and see if the relay is releasing when you turn off the breaker. hope this helped tim
Posted on Sep 07, 2010
Dometic roof top Air conditioner,Convert analog to ditigal control and thermostat, any help.
Depending on what model AC unit and control box is in the upper unit. Call or e-mail dometic and get recommendations first. ( dometicusa.com ) You'll be glad you did. Been there, done that.
Apr 16, 2013 | Dometic Heating & Cooling
Our penquin dometic air conditioner in the bedroom pours leaks lots of water when the unit is on during rain storms. Water leaks into the ceiling and also out the unit.
Sounds like base gasket at roof is loose or defective to start with. Try removing ceiling assembly enough to tighten 4 bolts that secure roof unit to inside bracket. Do not compress too much, just snug them all evenly and see if water slows or stops. If not, you will have to remove upper unit (roof) and replace gasket and re-secure but don't tighten to excessive, only compress gasket approx half of original thickness. Also make sure upper unit is aligned properly with opening of roof.
Sep 23, 2011 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Both roof top units on RV cool for awhile the go off
May be low voltage problem or bad connection this may cause controller to shut one or both down. Need to talk to RV dealer for assistance on this system.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
1993 325i Power Convertible Top will not open
has to be rest and tested by bmw dealship something has caused the roof to stop possible the control unit failed, a faulty microswitch in roof or the straps in the roof have failed and thrown it out of timing, cauing it to shout down system.
Nov 30, 2008 | 1997 BMW 318
Seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
59 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
