Question about Wurlitzer Jukebox CD Player
Wurlitzer 1500 won,t go through the entire selection process. disk stop short of fully coming out but the rest continues and always wats to pull the same disc out.
  • Wurlitzer Expert
  • 567 Answers
I dont know that model but i have the service programme for the wurlitzer one more time if thats any use to you email me at
philhemmings@hotmail.com
Posted on Sep 08, 2010
Wurlitzer 1015 jukebox
It is the arm sensor for the end of the disk.
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 one more time 50 CD player, it is reading error 0008 checked k7 switch, and arm making good contact. Just picks up cd puts it on tray then goes back to carousel continuously. Pulled bot
If it isn't K7 actuating bracket, or actually K7 microswitch it is a problem with the Selection and Credit Computer. It was a fault with some transistors on that board which showed that fault (if it really isn't K7). You can get them mended at www.wurlitzer.co.uk
Dec 28, 2014 | Wurlitzer Jukebox 1015 One More Time...
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
My tablet keeps stopping unexpectedly at the home screen and there is no way to stop it. can you reset this unit?
Are you trying to wipe the data with the reset? This will get you back to factory settings. It is entirely possible that there are apps on the tab that need to come off and have caused a problem.
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Mar 04, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
I have a wurltzer CD 100 disk player. I think the
Either the CD player, CD control unit, or Selection & Credit Computer are defective. I can help over the phone with troubleshooting, please email tech@wurlitzer-ohio.com.
Jul 30, 2010 | Wurlitzer Jukebox CD Player
Wurlitzer OMT, takeout arm continues to cycle all the time
There is a white bracket on the far side of the gripper arm which comes loose so it doesn't click the microswitch beneath it. To prove this press o the bracket when the arm is over the cd magazine and it will stop.
Oct 11, 2009 | Wurlitzer Jukebox 1015 One More Time...
Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Jun 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
2900 Keeps playing records
THE WURLITZER JUKEBOX WILL CONTINUE TO PLAY SONGS AS LONG AS ONE OR MORE, SELECTING PINS (THERE ARE 200 IN THE 2900 ONE FOR EACH SONG. THE PINS ARE IN LOWER SECTION OF THE CASE. BETWEEN THE SPEAKERS , AND LOWER DOOR.)
REMOVE LOWER BACK DOOR. WATCH THE ARM THAT STOPS ON THE NEXT RECORD, BECAUSE THE PIN IS UP. AFTER STOPPING ON THE PIN, THE ARM PUSHES THE PIN DOWN. THAT IS THE NORMAL OPERATION. IF THE PIN, IS NOT PUSHED DOWN, IT WILL PLAY THAT OR ANY OTHER SONG THAT HAS A PIN IS RAISED UP. THE PINS ARE THE MECHANICAL MEMORY FOR THAT JUKEBOX.
TURN OFF POWER, ==PUSH ALL PINS DOWN== THE SONGS WILL STOP PLAYING. THEN MAKE A SONG SELECTION. THE ONE PIN WILL POP UP THE MACHINE SHOULD PLAY THAT SONG.
WATCH THE ARM THAT STOPPED TO PLAY THE SONG, PUSH THE PIN DOWN. THAT IS THE SEQUENCE OF THE 2900 MACHINE,
WHAT CAN GO WRONG IS AS FOLLOWS. ==THE ARM DOES NOT PUSH PIN DOWN== THE ARM MISSES PIN== THE ARM NEED OIL, IT IS NOT LUBRICATED.==.
Mar 08, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
136 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
