Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Aghgahgahgasgasdsddsfagd
Hello
At the link below you will be directed to a tip i wrote on how to recover your PUK CODE.
Click HERE.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Contact the service Provider......
SOURCE: fix a PUK telus simcard
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact
your sim customer care department over phone. Its free of cost to get
the pin or puk no. If you cant contact through your phone get some other
phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software...
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too.
http://www.fixya.com/support/t3079596-sking_puk_code
SOURCE: I need the PUK code
Hi, your PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. It's free of cost to get the pin or puk no. If you can't contact through your phone get some other phone and contact them, or go to the nearest service outlet of your service provider they can also help you.
SOURCE: i need my sim unlocked
PUK is sim specific and has nothing to do with the phone. It's the security embedded on the sim card. You have to get the PUK code in the card attached in the sim card packaging when you bought it and enter the PUK Code to be able to access your sim. If you can't find it, you have to report to your telecom provider. If they can't do anything, it's time to buy a new sim card.
SOURCE: I need a PUK code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved OR: If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
