Question about Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
I push scglage button and unlocks the lock - Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
Http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx#5
Why can my electronic keypad deadbolt (BE365) be unlocked without a four digit user code when I press the "Schlage" button?This is most likely due to an installation error. When the lock is assembled on the door, two steps of the installation must be followed to insure proper operation. The deadbolt must be installed in the door edge with the bolt retracted, and the gray plastic cam on the interior mounting plate, through which the flat metal driver bar passes, must be pointed down (see below). The gray plastic cam has a triangle embossed on the end opposite the driver bar which should align with a matching triangle on the orange plastic cover plate below. These instructions are also embossed on the orange plastic plate.
Troubleshooting Image 2
If the cam is improperly aligned, the lock must be disassembled to a point where, with the bolt retracted, the cam can be turned to the correct position without moving the bolt. This will require withdrawing the flat driver bar completely from the cam before turning the cam. The driver bar will then pass through the cam at a forty-five degree angle when the lock is reassembled.
Posted on Sep 16, 2010
My 2004 Town and country van had to be jump started and now key fob won't lock or unlock doors.Took key fob to locksmith he said key fob was working, van was not reading signal and he didn't know what
The fob may need to be reprommed to the car. Do the following:
Grab your working remote. Push the LOCK button five times, allowing exactly two seconds to pass between each press of the LOCK button. Insert the ignition key and turn it to RUN. Push and hold UNLOCK on the working remote for 6 seconds. Push and hold PANIC for one second while continuing to hold UNLOCK. Release both buttons at the same time.
Push any button on the remote to program it. Then push any button on the remote that was already programmed. It has to be reprogrammed. The remote is now programmed to the vehicle. Turn the key to OFF.
Oct 28, 2014 | Cars & Trucks
Transcend microsd card unlock security
      • 1 Take the card out of the device.
      • 2 Locate the small button on the left side of the Transcend SD. Check to see if the SD card is locked; if the lock is pushed downward, it is.
      • 3 Push the locked button up to unlock the Transcend SD card.
Oct 21, 2013 | Electronics - Others
When locking doors they unlock
What's the year, make and model of the vehicle? Are you saying that the door locks cycle...like the door is open when you try to lock it?
Dec 14, 2012 | 2101L Keyless Entry
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
CHevy cobalt door locks- lock and unlock while I am driving had key fob reprogrammed and it was ok for about two hours and started all over again. What can the problem be?
Could be a problem in the shiftier. Your car doors lock automatically when you put the car in drive. They unlock when you put the car in park. The switch located in the shiftier can go bad causing the locks to randomly lock and unlock. Also, this can cause the key to get stuck in the ignition.
Oct 20, 2009 | 2005 Chevrolet Cobalt
I have a Whirlpool Dishwasher and it is locked and I don't know how to unlock it
I have a Whirlpool dishwasher & locked mine by pushing the "Air Dry" button for about 5 seconds. To unlock it, I pushed it in again another 5 seconds and the unlock light went out & it worked fine. Whatever button you locked it with originally (if you know), should unlock it when held in again.
Jul 16, 2009 | Whirlpool Dishwashers
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Unlock my blackjack 2
i think all you have to do when the phone is locked is push the top left (...) button right under where it says "unlock" on the screen. Then push the */sym button next to the zero. I have never needed a code to unlock. also, when your phone is locked, you have to lightly push the power button on the top of the phone to get the screen back on.
Apr 29, 2008 | Samsung BlackJack Smartphone
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
758 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
