Question about Canon PIXMA MP760 All-In-One InkJet Printer
I am having trouble with the yellow. I have tried changing ink tanks, the yellow still doesn't print, all the other colours are perfect. I've done all the maintenance procedures with no luck.
  • Vanessa Auty Sep 07, 2010
    I have done several nozzle checks (as well as other maintenance cleaning) and the only colour that doesn't print at all is the yellow. Wouldn't the other colours be affected if it was the drivers? I've had the printer for over 5 years now.....I've been very happy with it, but I guess all things wear out eventually....I was hoping it was just a minor/fixable problem.
    Thanks....i'll try anything before having to buy a new one!
  • Canon Master
  • 4,737 Answers
If you've changed the cartridge and the problem still persists, then it must be the print head which is causing the problem. Perhaps the portion of the print head where the yellow cartridge is blocked or some ink clogged on it.
To fix the issue, simply open the machine, remove all the cartridges, remove the print head and dip it (the print head) in a bowl of warm water for few minutes and clean it. Don't use any cleaning material like brush or your hand to clean the print head, use only water, just wave it inside the water. After it's cleaned and dried, reinstall it on the machine.
You also need to clean all the contacts on the cartridges, use a piece of cotton dipped in alcohol/acetone/spirit to clean the contacts (dotted metal contacts on the cartridges). Wipe them properly and very gently (you might damage it, do it very carefully).
In addition to the above mentioned tips, you can also clean the machine thoroughly using a blower and a brush.
After everything is cleaned and dried, reinstall all the removed components and try again. The machine and the print should work properly by now.
If you need further help, let me know.
(Note: You can also use Cleaning Kit solution instead of warm water, but warm water is better to get rid of the dried ink quicker.)
Good luck.
Thanks for using FixYa.
Posted on Sep 07, 2010
  • 857 Answers
Sometimes you can have a faulty ink cartridge. Although the ink levels are full it maynot print one particular color.
Try reinstalling the drivers, taking ink cartridge in and out, if that fails the i'd say its foo barred...
Purple blue etc, are printed by mixing the yellow,green and red inks together (the primary colours). If you've just bought it i'd take it back, otherwise i think its time for a new printer.
  • Jayant Jha Sep 07, 2010
    I understand what you are saying but sometimes it works if you are lucky,
    else its a defective ccartridge otherwise i think its time for a new printer.
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
My Business Inkjet 2280 will not print yellow properly. Its a brand new ink cartridge and my printing comes out striped. Ive tried cleaning and resetting, what do i do?
Try replacing the yellow Printhead. The printheads are inside the print carriage, usually a purple coloured flap, acessible from the top of the machine, and often confused with ink tanks.
There is a ink tank for each colour, and a seperate printhead for each colour....
Dec 21, 2009 | HP inkjet 2280 Printer
Print heads and test prints fine......will not print ay documents
I subsequently discovered that only black would not print - the other colours did. The following solution should work for any colour
Turn on the printer
Lift the front cover so that the ink tanks line up at the front
Move the grey arm to the right of the yellow upwards
Remove the ink tanks (in my case 4)
Carefully lift out the plastic holder for the ink tanks, this I believe holds the print heads
Clean the head(s) using cotton buds and injet refill ink cleaning fluid. I get mine from Tescos with my refill inks.
Replace everything and hopefully your printer will be o.k. Mine was
Jun 05, 2009 | Canon BubbleJet i560 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
Printing problem with Canon iP2600
Appears to be a defective color cartridge. Verify the printing is not set to fast or draft.
Dec 15, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
old marine
old marine
