Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
The file transfer speed for my external hard drive is extremely slow...as in it takes days to transfer a few gigs. In addition, it takes forever for the computer to read the hard drive. It was not always like this, but it is essentially unusable. How do i fix this?
  • Western Digital Master
  • 27,725 Answers
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
Try replacinng all leads that are attached to your external hard drive
then try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Posted on Sep 08, 2010
Slow transfer external hard drive
Both devices must have USB 3.0 capability to enjoy the high transfer speed that 3.0 has to offer. Check the other device (not the Buffalo) as see if it has USB 3.0 support.
First, make sure the firmware for the external and the source device are up to date. Next, try swapping the cable.
If that doesn't work, check the source and target hard drives to symptoms of failure. The transfer speed will be slow if one of the drives is failing. The manufacturer of the drive should have free diagnostic tools on their website. If not try WD Lifeguard Diagnostics or Seagate Seatools. If you are running Linux, go with smartmontools.
If the drives are healthy and if 3.0 is supported on both devices check the transfer speed with different files. Transferring one large file is faster than transferring a lot of small files.
If all else fails call Buffalo and request a replacement.
Jun 01, 2013 | Buffalo Technology Buffalo 1TB MiniStation...
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Western digital 1T external hard drive is taking way to long to copy files off my desktop. I have erased and formatted the hard drive and its still way to slow. It takes about 25 minutes to copy a 1...
Make sure that your PC supports USB 2.0, which is high speed data interface. Look for any such option in BIOS settings of PC and if available, enable it. On systems which do not support USB 2.0 interface, the data transfer is very low. You may search google for your PC Specifications and USB Support available.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Computers & Internet
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
File transfer rate is EXTREMELY slow
plz try to format the drive before transfer....
Feb 04, 2009 | Buffalo Technology (USA), INC. - 500GB...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
Jul 08, 2008 | Cavalry Storage Computers & Internet
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
