Question about Cps Products (CPSCC220) Compact High Capacity Charging Scale CC220
My CPS Products CC220 scale reads "Lo Cell" with new batteries. I cleaned the connectors, and checked the pc board for visual flaws.
I was receiving a LO error so I replaced my battery with a brand new 3V 2032 battery . I put it in the correct way and not my scale won't read anything.
Hopefully you did put it in correctly. About the only other thing you can check is to make sure that the battery contacts are squeaky clean and that the new battery is indeed good.
Sep 04, 2017 | The Health & Beauty
SYE 2002 A2 bathroom scale. Why is it reading 'lo' only? ,
The new batteries may be defective or installed incorrectly.
Nov 23, 2015 | Health & Beauty
What does it mean when my Boflex body fat scale reads Lo then turns off
My scale readout is now blank? Do I have to buy a new battery?
First, did you notice of the scale had a "lo" or "bat" display before it went blank? If so this means the battery needs to be replaced. If you did not get the battery indicator, did you "miss" seeing this? Has it been a week since you were on the scale? If you stand on the scale regularly and did not receive the battery indicator then you can try the reset procedure above.
Source: <http://www.taylorusa.com/faq-scales> Syz D
Aug 22, 2014 | Health & Beauty
My health I meter says lo so I changed the batteries twice and it still says lo
Clean the battery terminals with sandpaper or emery board.
Oct 22, 2013 | Health & Beauty
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
Cps Products (CPSCC220) Compact High Capacity Charging Scale CC220 Logo
131 people viewed this question
Top Cps Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cps Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
