Question about The Times Case Corporation Tractors International Harvestor
Looking for a diagram of the controls for a Case 1030 Komfort King Tractor,and type of hydraulic oil to use
3 Suggested Answers
  • 3519 Answers
SOURCE: i have a case 4210 farm tractor and need to know
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Posted on Sep 08, 2009
  • 6 Answers
SOURCE: where do fill up hydraulic fluid on a 1490 case
backend by the linkage someware, sory but dont know what oil to use
Posted on May 19, 2010
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
Looking for diagram for a case 1964 tractor of the rear gears.do you know were i can look?
go google and type in---workshop manual for case tractor 1964-- there are manual sites , tractor sites and a lot of other sites that can help
Oct 01, 2016 | Garden
What type of oil do you use in a david brown 880 selectomatic?
hydraulic oil suitable for the tractor
contact a service dealer for the exact type and viscosity
May 26, 2016 | Cars & Trucks
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Have a JD 2010.When engine is cold, the hydraulic does not react. When engine is warm, it is jerky. I am looking for the location of the hydraulic filter to see if it is clogged. Oil is fresh.
Look in front of the right hand side step, there is a round door with three bolts on the side of the transmission case, drain the oil first from the drain plug underneath.Remove the bolts and lever the door off, be careful there is a spring behind,the filter is a wire mesh type cartride and has a small wire handle to pull it out . wash the cartridge in solvent and blow clear with compressed air. Make a new gasket when reinstalling and use lots of Gasket sealant.
Nov 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
Sep 07, 2009 | The Times Case Corporation Tractors...
Case 1370 agri king runs wont move
have you checked all of the linkage and lines? filters? get pressure test on hydraulic system to see if pump is weak
Apr 11, 2009 | Diesel Case 1370,1470,1570 Tractor Piston...
The Times Case Corporation Tractors International Harvestor Logo
50 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
