Question about Garden
I have a mtd with a 14.5 hp i/c quiet. blew the motor bought another one and it will not idle up. runs i think about half idle. if i engage the tranny or the blades it boggs down but doesnt stall. i can see the governor arm move but it wont idle any faster. any help would be greatly appreciated. thank you
  • 472 Answers
Sounds like its out off adjustment unhook the throttle push the handel all the way to the choke spot then pull the cable untill you see it close the chok on the engine then titen it up let me know if this works and if it dont or if you need any thing eles let me know
Posted on Sep 07, 2010
Installed new MTD 951-12771A carb how do I set idle
if it is a older model it will have 2 screws with springs 1 is idle the other is high speed screw both in but not hard back both about 1and a half turns out start motor and fine tune them
Jul 05, 2017 | Mtd Garden
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
14.5 HP MTD MOWER WON'T TURN OVER
Can you turn the motor over by hand? Make sure it's free and can turn. Is starter drive engaging into flywheel. If mower was run with low oil or on a slope it may have seized up.
Jul 25, 2013 | Mtd Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
My swisher T 60 finish mower with a 14.5 hp Briggs motor just died on me in the middle of mowing the other evening, and I assumed that I'd run out of gas. But, it had about 1/2 a tank. It starts up and...
if an electric pto , the problem is the pto is taking all of the power and robbing the ignition system
indicates a failing charging system or voltage regulator
Feb 05, 2018 | Swisher T14560 T - 60" Trailmower with 14...
My 17.5 hp MTD yard machine does not try to start
be sure blade isn't engaged, check voltage at battery, depress brake and sit on machine to start, check connection on switch and battery
Jan 25, 2018 | Mtd Garden
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
