Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
I need to buy a new thread tree for my brother overlocker but where?
    Genius:
  • 1,788 Answers
Go to sewingpartsonline.com or brother-usa.com
Posted on Sep 12, 2010
Can't get overlocker to stitch, followed manualcorrectly still cant get machine to stitch
Try rethreading completely from the beginning. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread in the order specified in the instructions. Give each thread an extra little tug between the thread tree and the tension dials to make sure it is seated completely in the tension disk.
If you do all this and still can't get it to stitch, then you may need to take it for service.
Apr 23, 2018 | Sewing Machines
My serger will not make a chain and won't sew. I've checked the threading, and it all seems okay. Any ideas on why it won't sew and make a stitch?
Usually it's because the machine is not threaded correctly. Consult your owner's manual. Remove ALL the thread and start over from the beginning. Make sure to RAISE the presser foot before threading. Thread each thread in the proper order (usually upper looper first, lower looper second with the thread tail draped over the top of the upper looper as the last step...), then thread the needles. Tug the threads to make sure they are each seated in the tension disk. Check that you are not missing any steps in any of the threading. It would probably help to use different colors in each one so you can tell which thread is causing a problem. If thread is breaking, check to make sure any of the threads are not wrapped around the spool pin or the thread tree.
If any thread breaks, it is good practice to remove all the threads and rethread everything from the beginning. It will save you a lot of frustration in the end.
To start off, set all the tensions to the halfway point. This is the standard factory setting for basic overlocking.
Troubleshooting:
If the left needle thread is breaking at the needle, try a new needle and make sure it is inserted correctly and all the way up. Give the thread a tug and see if it pulls through the tension disk. Could be looped around something or the tension disk is not working properly--piece of thread, lint, gunky, or defective/broken.
https://www.youtube.com/watch?v=5ohtf7H_gyc
http://www.makeithandmade.com/2012/08/threading-your-serger-or-overlocker.html
http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=50864
http://community.babycenter.com/post/a42582709/serger_thread_keeps_breaking_-_help
http://davesgarden.com/community/forums/t/1067745/
http://su-sews-so-so.blogspot.com/2012/01/threading-brother-1034d-overlocker.html
Dec 16, 2015 | Brother 1034D Serger Sewing Machine
Brother overlocker
Hi there
Please can you help. I bought a second-hand brother M14-B551 overlocker. The needle broke and i am now battling to thread . Where can i get some help.
Jan 13, 2014 | Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
Thread Keeps snapping on my 4th reel brother 1034d overlocker
I was having the same problem. I was trying to thread only that 4th one because it keep breaking. It did not stp til I rethreaded all the threads and did it worked fine
Apr 06, 2009 | Brother 1034D Mechanical Sewing Machine
Brother LOCK-523N overlocker threading
Looking for the manual for the brother lock-523
Nov 11, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother Serger 634d
where can i buy a new thread tree for my 1034d brother overlocker from betty c
Oct 30, 2008 | Brother Lay-In Thread Serger Mechanical...
Brother 925D - threads do not lock
threads do not overlock stich
Aug 11, 2008 | Brother 925D Serger
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
334 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
