Question about Whirlpool Washing Machines
I have a whirpool washer model tw57esvw0 Beginning today, when starting a load, the machine does not fill with water first, it immediately starts agitating and after about 5-8 seconds it starts filling with water as it continues to agitate. All settings of the dial have this issue and all Fabric Selections except Delicate. Put it on Delicate and the washer works as always. What is wrong?
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
  • 319 Answers
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Posted on Jan 04, 2008
  • 5911 Answers
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
  • 1031 Answers
SOURCE: No water is coming in the washer before the agitator starts
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
Most washing machines are controlled by software programmes these days and produce error codes if they don't detect the correct amount of water has been taken in within a set amount of time. The error code for not filling should be mentioned in the instruction book
Washing machine making a humming noise when trying to fill?
If the washing machine wont take in any water at all, plus you can hear a humming noise (not normally present), check that both your taps are turned on, or that the water supply hasn't been cut off in someway. A gentle humming from the back of the washing machine could be the water valves being energised and trying to take water in.
  1. Carefully pull the washing machine out ,Turn off the taps supplying the washing machine
  2. Unscrew the fill hose(s) (Have a bucket or bowl and towel ready, there may be a spurt of water at first due to the pressure in the hose)If you get a spray of water coming out that lasts longer than a second or so the tap may not be actually turned off properly.
  3. Hold the hose over a bowl or bucket and switch the tap back on to see if there is a decent supply of water coming through the hose
  4. Adequate water supply available?
    If water comes through at a decent flow rate then check the filter in the water valve on the washing machine. You can pull it out with a pair of pliers and clean it. However, this will only explain your fault if it is severely blocked up, which is rare. Be careful not to damage the filter with the pliers as they are often delecate and brittle. If you create a hole in one - even a small hole - it can let grit and even small stones through into the water valve and damage it resulting in possible flooding in the future if an obstruction stops the valve shutting off properly.
    No adequate water supply coming through the hose?
    If no water comes through the hose, or the flow is very slow, then the fault is in the plumbing or there could be a kink somewhere in the hose. If your machine was plumbed in using those self plumbing taps that clamp on to the copper water pipes then they do sometimes get clogged up and need the hole clearing. If this happens to the cold supply it can be achieved by turning the stop tap off first, but if the hot supply is blocked - which is the most likely of the two - then you have to turn off the cold supply and then drain the hot water tank by turning on the hot tap until the water is drained out (unless you know where the valve is to turn the hot water off in your water cylinder).
    If your machine is plumbed in using the ubiquitous blue (and red) levers to turn the tap on and off they can commonly go faulty where you think you've switched it off or on but only the plastic lever has moved and it hasn't actually operated the valve inside the tap. This is typically caused when the red or blue plastic lever cracks. You can usually operate the tap using pliers.
Posted on Mar 29, 2009
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer starts agitation during water fill up and after spin cycle ends washer fills back with water and leaves clothes very wet.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Oct 20, 2010 | Whirlpool WTW5850S Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Sep 23, 2008 | Maytag MAV6200 Top Load Washer
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
