Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I have a Whirlpool Duet dryer and it cut off and there is a flashing error code on the panel F01 and it will not respond to any of the buttons
  • Anonymous Mar 26, 2014
    f01 code
  • Anonymous Mar 28, 2014
    A f01 error code
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Whirlpool Duet dryer model WED9200SQ0 shows error code F01 what does this mean and how do i fix it
F01 is a main board fault...
https://youtu.be/n_e7CcpfCNk
If the main board is good then there is also a fuse which may have blown.
https://youtu.be/HGegabpM3jM
You will need a soldering iron... if you feel capable then proceed of find someone who is..
It's actually quite easy to do...
Apr 17, 2017 | Whirlpool Dryers
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I am getting a F01 code on my whirlpool duet steam Dryer. MOD: WGD9600TWO
The F01 error indicates a primary failure of the control board. Try unplugging the dryer for a while (20-30 minutes); this will reset the control board if the problem was caused by a power surge. This will reset the internal breaker on the dryer. If the error recurs, the main control board needs to be replaced. However, you should inspect the wiring and the motor just to make sure that no other parts have been damaged by whatever caused the board failure.
If the model number of your dryer is WGD9600TW0, then the control unit is part w10141671. See http://www.searspartsdirect.com/part-number/w10141671/0026/110.html . Sometimes, you can repair the old control board by soldering a jumper wire (16 AWG) across a damaged solder connection for one of the relays. However, if you aren't careful, other parts on the board may be damaged beyond repair.
I hope this helps.
Jul 23, 2015 | Whirlpool Dryers
How do I fix an F01 error on my whirlpool duet dryer?
you have a bad computer board
http://www.fixya.com/support/t24940167-dryer_flash_f01_kenmore_dryer_model
Jan 10, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
Error code F01 on Whirlpool Duet gas dryer
this is the main control board error,if you send the model number i can look it up for you.also have you tried unplugging it for like 15 to 30 minutes,i've seen the reset themselves just like rebooting your house computer.
Sep 21, 2013 | Whirlpool Dryers
After pressing the pause button on my Whirlpool duet washer I got an F01 error code. From checking around online, it seems that this happens to alot of people when they use the pause button. Would this be...
Error code F01 =EEPROM ERROR
A communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred.
PUMP DRIVE ERROR
The pump driver fails to activate.
MAIN RELAYS ERROR
One of the main relays is not working properly.
A power glitch may cause this error.
Unplug washer or disconnect power for two minutes.
Verify CCU operation by running a Diagnostic Test or any cycle.
Replace CCU board.
The relay might be soldered or always open.
Replace CCU board.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
3,911 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
