Question about Rowenta DG-980 Iron
Water tank Laying inside the fill tank, across the bottom, is a grey tube. Apears to be made of rubber or some pliable material. It has a split in it. Will this effect the operation and what is this tube s function. While cleaning the iron and rinsing out thw presssure tank a small brown item dropped out. It appears to be made of plastic and looks like a filter screen. It's about a 1/4 inch in diameter and 1 1/2 inch long I don't see where it goes and can it be left out? Thanks, John
    Scholar:
  • 70 Answers
Depending on the age of the reservoir, the earlier version had two pickup tubes that were "Y" together to allow water pickup along the extreme ends of the reservoir. Later versions had a single "L" tube arrangement that was shorter, but did the same thing. As long as the split is submerged, the pump should still be able to draw water when the level is quite low, but once air gets in, the pump will "cavitate" sucking only air and lose prime (like a siphon hose that picks up air). As for the brown filter screen, you will probably have to ask a Rowenta service center, and hopefully get some friendly advice...!
Posted on Jul 02, 2008
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 | Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Too hot to handle spits water from sides Bosch sensixx B10L
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Dec 22, 2012 | Bosch sensixx TDA 8333 Iron
Rust coming out of steam holes
dump what water is still in iron. refill with white vineger turn turn on after a day soaking with iron hot use on old towel. dump remainer out. hint when filling iron with water only put small amount so water isn't laying inside when not in use.
Aug 05, 2012 | Rowenta Irons
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Rowenta Professional DM890 Iron with Auto...
My Tefal Steam generator needs de-scaling i have the kit but I have lost the instructions
you can download new instructions from the web. Remove the anticalc cover at the side and unscrew the metal nut, take care to ensure the little rubber seal is still inside the nut and not stuck to the opening. Plug one end of the hose into the iron ( it will fit without moving as it can only go in one way) connect the other end to the tap, turn on the tap and watch it flush out all the build up. leave it flushing for a few minutes then turn off the water. personally I then empty all the water from the base and then put the nut and cover back on fill up the tank and iron.
Jun 05, 2009 | Tefal UltraGlide plus 1656 Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
No Drain Knob on my Singer CSP 1
I would think that your water tank in missing a grey rubber bung, which pushes in to a small hole under the water tank.
Mar 05, 2009 | Singer CSP1 Iron
Water Leaking
The seal between the top and the bottom plate has lost it's integrity. First try tightning the 2 screws on the underside of the iron. If that doesn't fix the problem, then you will need to take the iron apart and fix the seal. That will require you to remove those 2 screws and also a third screw that is up by the toe of the iron underneath the sprayer. You will then need to slowly pull the 2 pieces apart becasue the seal is made of a sticky rubber substance. Once you get it apart, you can then distribute the seal material to cover the bad area. Then just put it back together!
Dec 15, 2007 | Rowenta DZ1700 Iron
Rowenta DG-980 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
