Question about Electrolux EIED55H Dryer
Error message e64 - Electrolux EIED55H Dryer
  • 4,323 Answers
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and
Posted on Sep 13, 2010
What is wrong with a code e64
It probably requires a technician to test it.
You haven't identified the manufacturer and model, but it is likely the following result of a Google.com search suggests a problem:
https://www.justanswer.com/appliance/7f3w8-frigidaire-dryer-e64-error-code-dryer-will.html
Why Am Getting Error Code E64 On My Frigidaire Dryer
Mar 19, 2018 | Dryers
My Frigidaire Dryer (Model #FASE7073LWO has a error "E64" listed on the window. What error is this in reference too?
E64 means Heater Open Circuit. Either your heater coil is blown or you have some bad wiring to the heater coil.
Dec 16, 2014 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Jul 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
After my xbox boots up, one red light comes then E64
E64: DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update. http://forums.xbox-scene.com/index.php?sho...p;#entry4156375 This might also be caused by a bad SATA cable.
Feb 14, 2010 | Microsoft Xbox 360 Console
I have error e64 no screen onxbox360 210g
Try flashing your drive with new firmware. E64 is a DVD drive error.
Jun 28, 2009 | Microsoft Xbox 360 Console
Electrolux EIED55H Dryer Logo
3,966 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
