Hi good night my son was playing with my ac remote now i can seem to turn my ac on with the remote how do i correct this problem ?
  • 455 Answers
Hello Try pushing in the master reset with a ball point pen,a small hole on the face of the remote or take out the batterys for a couple of hours.
Posted on Sep 07, 2010
Acer tablets
Did the AC/DC jack get damaged when it was "stepped on"?
Mar 28, 2013 | Computers & Internet
TV turns on in the middle of the night
  1. If the TV has a timer option, ensure it is disabled.
  2. Check the remote control to see if any of the buttons are stuck that may be interfering with the TV.
  3. Unplug the power cord of the TV from the AC wall outlet for 60 seconds.
  4. Plug the power cord back into the AC outlet.
  5. Attempt to turn on the TV.
  6. Remove all remote controls from the room where the TV is located.
OR
unplug all HDMI sources to see if a device is sending signals in the middle of the night
Oct 03, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Hi i have a 40inch bush tv my partner was using this for his computer screen last night like he does all the time but for some reason it turned itself off and now wont turn back on. The standby button is...
Is there anything power signal lights?If there is no signal power lights,it is totaly dead set no power.First step is to check the power outlet,then the AC cord if there's a ac power.If the AC cord is good,check the fuse,located at the power supply.Replace same value of fuse if busted.Try this sugestion or procedure.Thankss...
Aug 26, 2011 | Bush Televison & Video
Peavey TKO115 bass amp. Any help on where to buy parts? My son's amp needs a new AC power receptacle. It works, but was smashed loading it one night.
If you're living in the States, you can go to any RadioShack store.
They can help you, it's nothing special.
Good luck,
Gerard
Jan 24, 2010 | Peavey EQ215FX Home Equalizer
Lights flash on the unit at night making it hard to sleep!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
Feb 26, 2009 | Sharp XL-DK225 Shelf System
Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Jan 30, 2009 | Heating & Cooling
LG KF510 will not turn on
Take it to the repair shop. My son's KF510 did the same. I await the results of the autopsy!
It started to play up almost straight away when he bought it a month ago. Last night it failed to go past KF510 logo then goes to a low level purple screen. Removing the battery seemed to fix it prior but not now!
Jan 01, 2009 | LG KF510 silver on Orange Pay As You Go...
Pincussion/Geometry/Convergance Problem
If you can not correct the convergence with custumer settings is because something went wrong inside the tv and it has to be diagnosed and corrected by a service technician,you are correct there are setting you can access with the remote but are usually adjusted after you have replace a major component.I would suggest you call for service,I do not believe is a problem you created or you could have prevented.
Sep 27, 2006 | Philips 55PP9352 55" Projection Television
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
