Question about Fujitsu M3099GX Path-Through Scanner
Fujitsu pass through scanner issue
The scanner is taking too many pages at once.
  • 25 Answers
1. Try changing the separater roller and belt. They do wear out and are consumable. Kits can be found on the internet.
Posted on Jul 08, 2008
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
Error Code : 0x5a
The detail code 5a in Fujitsu fi-5900 scanner is displayed due to frequent paper jam error. To resolve this issue, you need to clean the two lenses of JAM1 sensor and check it's performance.
Also, to resolve paper jam error, you need to check the condition of pick,separator,brake rollers, feed and pinch rollers. Replace the rollers if required.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 01, 2014 | Fujitsu fi-5900C Pass-Through Scanner
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Cannot load drivers for Fujitsu fi-5015C, once loaded, computer restarts and when windows comes back up it states there is new hardware that needs software downloaded, rather than starting the new hardware...
kindly download the new drivers for fujitsu Fi-5015 scanner from the below link and if solved/unsloved let me know i will guide you to solve this porblem,or mail me in felixsimon22@gmail.com
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
regards
felix
Mar 21, 2011 | Fujitsu ScanPartner fi-5015C Pass-Through...
Paper jam
It seems youre facing an issue with the scanner consumables - pad and pick roller. It is a goos idea to replace both of them at the same time. Also check the feed and exit rollers (the two rollers on the upper part of the scanner) as the get sticky causing problems like the one you describe.
Sep 27, 2017 | Fujitsu ScanPartner fi-5120C Pass-Through...
Number of Pages the fi4120c will scan
Try to get to the separation rubber and clean it.
Nov 04, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Jun 27, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Scanning problem!
First Scan only a single page and note file size. Now scan 3 or 4 pages ad check the file size. If it is more, then the scanner is clubbing/collating all the images into a single file. Check your software settings and disable this feature if you want individual files.
S. Mohan
Mar 12, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu M3099GX Path-Through Scanner Logo
48 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
