Question about Sharp LC19DV22U 19 in. LCD Television
I need to do a channel set up with my Sharp lc19dv22u tv so I can receive HD signals over my coaxial cable. I have lost the remote and the universal remote does not work for the menu button
5 Suggested Answers
satavlad
  • 405 Answers
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Posted on Nov 03, 2009
bshldn
  • 736 Answers
SOURCE: Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Posted on Jun 07, 2010
  • 8457 Answers
SOURCE: I have a Sharp
No ways,try website Remotes.com to buy an exact remote as ur original remote.
Posted on Dec 08, 2010
Some universal remotes still won't allow you to access the menu. If you get a universal remote that will do everything except access the menu, there is a back door into the menu.
You need to hold the volume down button on the tv and then the 0 button on the remote. After a couple of seconds of holding them both down, it will take you to the menu to change a password. From here you can use the tv's volume and channel buttons to navigate the menu.
Posted on May 23, 2015
Do you have to have an optical cord from receiver to tv..koss model ks3102..if not i have rca cords were do cords go.
HD broadcasts by TV stations are often broadcast in Dolby Digital. If your TV can output Dolby Digital or HD then you will need to have the TV connected to the receiver via either the optical in, or the coaxial in. If the receiver can get the Dolby signals via the Coaxial and the TV can send them via a Coaxial socket it should work. Don't forget to set your HD set to output Dolby signals. If the TV or Receiver can only send Dolby via the optical you will have to use that. Optical cables can be picked up cheap these days. I have seen them in pound shops!
Sep 09, 2015 | Audio Players & Recorders
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
Sharp LC19DV22U 19 in. LCD Television Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
