Question about Kitchen Ranges
I am looking for the specifications for the Amana AC70KW. We bought it in 2001 and have not hooked it up yet. (Too much of my wife's clutter in the garage.) I am looking for the voltage, wattage, cu. ft, etc. Can you help me please. I cannot find the specifications on the internet. Thank you, Jim Laurin
MNTECH
  • 1543 Answers
SOURCE: cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Posted on Sep 16, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • 686 Answers
SOURCE: F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Posted on Apr 08, 2009
SOURCE: How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
Posted on May 02, 2009
SOURCE: I need to know where to find the defrost timer on
I just replace my defrost timer & defrost thermostat. The timer is in the front bottom. Remove the kick plate at the bottom & you should see an orange knob. It takes about 10 min to replace. The thermostat is located in the freezer section. Remove the lower panel. This will expose the cooling coils and the defrost thermostat. Takes about an hour to replace.
Posted on Jun 16, 2009
What's the cubic feet of Amana TM17tbw refrigerator?
Yes, probably 17 ft^3.
Open the door, look on the walls, find the information plate, and write down the model number and serial number. Then go to the Amana website and look up the specifications. " Amana TM17tbw" won't cross to a specification but the exact model number from the label on the wall should.
Jul 08, 2015 | Amana Refrigerators
My wifes 2001 Honda Odysseys battery did in a parking lot. Mall security hooked up the jumpstart cables wrong (I guess) now it won't start at all. Could he have overloaded the fuse? and is there
you need to look at the fuses in the under hood fuse box f you look at the center of the fuse and see if the line is broken in the center if so its bad
Sep 23, 2012 | 2000 Honda Odyssey
I bought Amana Chippers but I have some questions about how to use them. Where can I get information?
Take a look at the Amana website http://www.amanatool.com/
They have information about their products,safety guidelines and I even watched a couple of videos on the site. Good luck
Jul 17, 2012 | Fleer 5 2001 Focus Chipper Jones 130
Copper waterline is broken
Hi .. there should be piping connectors at each end of the tubing. I would disconnect those connectors andtake them to the building supply store and get new fittings and a new supply hose. The new hose does not need to be copper,. you do not need to cut the existing fittings off the wall or the fridge, the new fittings, or new hose can connect directly to the old fittings. my tool of choice is a pair of crescent wrenches
May 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Hooking up water to ice cube maker
On page 4 step 3 of the manual on link below tells you how to hook up the water supply for your fridge.
http://shop.amana.com/assets/pdfs/literature/004251.pdf
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
Yesterday, my 2001 sonata jerked and the check engine light came on. What could be the problem?
You need a code scanner hooked up to find out why the light is on, some sensor on the engine went. If there is an advanced auto or an autozone near you, take it there, they can hook one up for you free, that will tell you what is wrong. Takes about a minute to do. Some places charge almost a $100.00 to do. Without that hooked up, you won't know what sensor it is.
Nov 16, 2009 | 2001 Hyundai Sonata
Amana gas dryer fine on regular settiing, poor on delicate
It would be unusual but this could be a bad timer in the control panel. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.RepairClinic.com
http://www.repairclinic.com/Amana-Dryer-Parts?z=100
Jan 26, 2009 | Amana ALG331RAW Gas Dryer
Replace 2001 lesabre tail light lense
peel rug back from wall of trunk. there are bolts holding lense in/also they may look like tie down hooks they are actually nuts.
Nov 20, 2008 | 2001 Buick LeSabre
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
