Question about GPS
Karr alarm manual series 3 - GPS
2 Suggested Answers
  • 188 Answers
SOURCE: Disable alarm system
Try this http://adf.ly/3pDUa
Posted on Nov 22, 2011
How to activate karr alarm 2040
The Internet, though, has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors. Here
is just a sampling of what sites are out there:
Chilton Repair Manuals
http://www.chilton.cengage.com/
Factory Auto Manuals
http://www.factoryautomanuals.com/
web based auto repair manuals
Haynes Publishing
http://www.haynes.com/
Vintage Books
http://www.vintage-books.com/
AutoLit.com
http://www.autolit.com/home.htm
RepairManual.com
http://www.repairmanual.com/
Feb 10, 2016 | Cars & Trucks
I disconnected the Karr alarm system from my 2000 Toyota camry and now my ac, windows or gauges work. Can anyone help me?
I would start by checking the fuses for the componants that aren't working. Other than the guages, the other componants utilize relays as well. Check those also. If they still don't work you will have to trace them back. I doubt if these componants are at all wired through the alarm system.
Aug 10, 2014 | 2000 Toyota Camry
Nov 22, 2011 | 2001 Dodge Durango
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
Alarm is mal- functioning need to by pass alarm made by karr i think orinal equipment car starts sporatacly but have to play with remote to get it t o start help
It is simple just trace the wires - you will notice that installer will have teed in the wires – just cut off the T to the alarm - where you spot wires have been cut and attached with the alarm wires, just remove the alarm wires and rejoin the original wires and you won't face the alarm problem again.
A lot of owners coimment about Karr alarms and are so bad! Do yourself a favor and replace it (they comment like a personal opinnion).
I just got an accord and it came with a paper manual for the 2040. I had to reprogram the remotes though. Here is how Kar said to do it, you will have to fool around with it to figure out which buttons go to which channel, and I only had to press the button 3 times not on off to get it into the mode. So when it beeps once it meets its in channel 1, twice, channel 2:
* First, locate your valet switch. The valet switch is either going to be a small black push button, or a small silver toggle switch. The valet switch is either mounted on the plastic panel on the left side of the vehicle, near your left ankle as your sitting normally in the driver’s seat or directly behind the LED light.
·Turn your ignition key to the “on” position, or start the vehicle.
·Within 10 seconds
+ you have a silver toggle switch:
·Flip the switch “on” and “off” three times. (on-off-on-off-on-off) qIf you have a valet push button:
·Push the push button three times.
* The alarm system will chirp one time, letting you know that the alarm is in programming mode.
·Hold down the arm/disarm (center) button on the transmitter, until the alarm chirps again, confirming that the transmitter has been learned.
·Turn your ignition key off.
* The alarm will give one last chirp, letting you know the alarm has exited programming mode.
* The new transmitter is now programmed to the vehicle, and will arm and disarm the alarm system.
If you have problems programming the transmitter, please feel free to call at (949) 707-4210, or toll free at (800) 395-5277.
Here you can find your wiring diagram for Dodge Intrepid Car Alarm
Good luck.
Apr 20, 2010 | 1999 Dodge Intrepid
How to reprogram Karr alarm in Scion tc?
dealer only or wouldnt be any good as an alarm if any tom **** or harry can do it ,Try disconnecting the battery and holding the leads together for a minute then reconnect the battery
Aug 12, 2009 | 2006 Scion tC
05 Dakota remote wont work
That happened to mine too. Is it a "Karr" remote? If so, it seems as if they use really cheap switches. I ended up de-soldering a working switch from the trunk release circuit and soldering it onto the alarm arm/disarm circuit. Works perfectly now. If you don't own a soldering iron, I recommend getting a new one or getting a better alarm system.
Jun 27, 2009 | 2005 Dodge Dakota
ALARM LIGHT ON THAT LOOKS LIKE A TRIANGLE WITH ARROW CIRCLING IT. WHAT DOES IT MEAN
On a 1998 3 series (E36) BMW, this indicator lamp is for the ASC+T = automatic stability control plus traction. It should go shortly after the ignition is switched on implying that the system is OK.
If the indicator lamp fails to go out after the engine is started, or comes on in the course of normal vehicle operation it means that the system has malfunctioned. The vehicle remains operational, but without ASC+T. You a have an 2001 3 series (E46), but I suspect the indicator lamp means the same as the E36 3 series. Look in owners manual under "indicator lamps"
May 15, 2009 | 2001 BMW 3 Series
Car: 3 series BMW - Problem I can't reset the alarm
BMW 3 series 2007. Have changed tires, but cannot reset air pressure alarm ?!
Mar 26, 2009 | Anti-theft Alarm System 3 Series E90 E92...
GPS Logo
411 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
