Question about Brother XL-3510 Mechanical Sewing Machine
Fabric feeds through really slow
I have a brother xl3010 and it had been working great, I dont know what happened but now the stitching is so close together and if I look really carefully it does pull the fabric through, but in order for the stitching to look normal I have to manually pull it through from behind which is kindof a pain, I asked somone else and they said it was the tension, do you have any suggestions and do you think it is easy to fix if I could just do it at home?
thanks
Michelle
  • 323 Answers
Remove the needle plate and clean the feed dogs(the grooves between the teeth)
Sewman7
Posted on May 13, 2008
Should I trade my Singer Merritt 3130 for Brothers JX2517
A: You asked, "Should I trade my Singer Merritt 3130 for Brothers JX2517". Ultimately, it is up to you, as to whether you prefer the more vintage aspects of the Singer-Merritt 3130, or the sewing feel you get from the newer Brother JX2517. If you have been sewing on a Singer-Merritt 3130 which is in proper adjustment for some time and you are used to the sound and feel of this heavier machine, I think you will have more than half the answer already.
However, do compare your Singer Merritt 3130 it to the Brother JX2517. Though I have not used that particular model Brother, I have sewn on several modern "plastic" Brothers, that all sewed very well (most Brothers are great machines), but were all much louder and more rattly than the three Singer Merritt models I own (two Models 4552 (the first one I owned quickly became my favorite GO-TO machine for most tasks) plus one more modern "plastic" Singer Merritt 9618, that I was quite impressed with too, though it is a different ball game.
The Brother JX2517, looks as if it has a lot of bells and whistles, and does 17 stitch patterns and a 4-Step Buttonhole; it might be OK for you, but you must do some sewing tests with both. Because this Brother it is a modern machine, it won't take much maintenance, but if something goes wrong you probably will not be able to fix it yourself, and will need to take it into a repair shop (where, unfortunately, they may just want to sell you the next new model they have in stock).
When it gets down to really sewing, the added fancy stitches will not matter to you at all. What you will want is a machine that lays the stitches down where you want them, predictably and reliably without missing a stitch, jamming or fouling. Try them side by side without the pressure of a salesman standing over you, nibbling your ear and praising the new machine and pointing out the limitations of your old machine. Test sewing on very thick folds of denim and also on very thin layers of cotton, rayon or even silk, but mostly test the type of stuff you usually sew. Look closely at the stitches, if either machine does not produce nearly perfect stitches, then you cannot make a decision right then, that is not until both have been properly adjusted to sew nearly perfect stitches (which I am sure both can be so adjusted). Only when both machines are sewing at their best, can you really compare the two for the finer details.
Try closing your eyes to just "Listen" and "Feel" each machine as it sews, but don't get your fingers caught ! Which machine would you enjoy sewing with in the long run. The answer should be clear, but if not, there is always another option.
ALTERNATIVE: If you are still not sure which is better for you, and if you are still hell-bent to buy yourself a new toy, then don't "Trade In" your Singer Merritt 3130, but instead Bargain with the Salesman or Owner, to get them to give you the "Trade-In Discount", without giving up your old machine. I did this on a new Singer CG590, but be careful, you may end up with more sewing machines than you have room for. Keep sewing.
Sincerely,
-- Amender (2016 FEB 24)
Jan 26, 2016 | Singer Sewing Machines
Stitch length for zig zag satin binding 8mm equals what number?
Neat zigzag stitches are usually achieved at "2.5" or below.
Closed up zigzag stitches (close together) are referred to as a
satin stitch its likely you will want to set for 1.5 or at most 2. http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual Look for page 40 in the owners book or scroll down and if you see numbers not on the page but on the scroll bar look for 47. It has some great pitures that can help you out.
May 13, 2014 | Singer 3116 Simple
I bought Brother sewing machine Model XL 2230, And could not get a good stitch. Keeps giving me loop either on top stitch or down stitch. Dont know if the single needle can't do straight sewing and dont...
The foot is on the side. Make sure it is clean. Take off the plate and remove the bobbin cleaning all the lint and thread out with q-tips. Oil if needed. Make sure you are using the same thread in the bobbin as on top. Rethread the machine making sure you do it correctly. Change needles using Schmetz as it is shorter and I have found Singer and white label needles are too long and cause problems and well as break easily as they hit the bobbin and cause looping. Not sure what you need to know about the foot. It should have a handle on it so you can put it up or down. Google Brother model XL 2230 and download a manual to find lots of info about your machine.
May 02, 2011 | Brother Sewing Machines
Where is the feed dogs botton on my brother xl3010. I need to drop them for quilting and can't fine the botton.Lost my book .thank you
The User Guide suggests there is a different Needleplate (must be thicker than standard) used for darning, free motion quilting etc.
Look HERE for a replacement manual for your Brother XL 3010
Bargain Box
Feb 12, 2011 | Brother Sewing Machines
The fabric isn't feeding and the stitches are really tight.
What is your stitch length set at? how high is your tension set? Try to set it between 3&4 then check. Your manual tells you how to do all of this. Go to Brother at www.brother-usa.com and download your manual for free. You can enlarge the diagrams and really see it up close. Good luck, if all else fails, call Brother at 1-877-276-8437
Oct 09, 2010 | Brother LS-2125 Mechanical Sewing Machine
I really need somebody to look at my sewing machine i dont really know what happen to it. I let somebody borrow it and it dosn't work now. Where can i go for a repair? I try some repair stores but they...
Call Brother at 1-877-276-8437 and they can tell you who their service center is in your area. Or go online and see if they list one for your area at brother-usa.com
Sep 05, 2010 | Brother CS-8060 Computerized Sewing...
Two Stitch Hang-up
youch!  how frustrating.  It sounds like there is a piece of thread caught in or around the bobbin casing.  take the whole casing out and clean with your brush.
I feel your pain, hope this helps.  If not, please come back and we'll try some other things.
Jan 18, 2009 | Brother XL-5130 Mechanical Sewing Machine
Fabric pulls down into bobbin area
Increase your top tension, from 2 to 4, or from 5 to 6. Also check if there is no fluff or cotton in the top tension blades, preventing them from closing properly. Do this by lifting the presser foot and decrease the top tension to zero. This open the blades and allows you to inspect them. Good luck!
Nov 06, 2008 | Brother LS-1520 Mechanical Sewing Machine
Ce5000prw recieving f5/e6 error message
I know this probably won't do you much good as it is now nearly 3 years after you posted your problem. However, I just had the same problem after using my machine for 4 years and couldn't find any solutions or answers anywhere, even from Brother, so I figured I'd post an answer in the event someone else has this problem. My local repair center wanted to charge $100 to even look at it since it is a computerized machine and Brother said the F5 code was not a good thing and I really needed to have it checked by an authorized dealer. You can get this machine brand new for $150 so I didn't see the point in spending the money to fix it.
I finally decided to open the hard case and see if anything was up. Yes, this voids the warranty but what good was the warranty going to do me anyway when I could replace it for less than any repairs would cost. When i opened the hard case, I discovered over 40 glass head straight pins scattered everywhere. I have a 3 y/o son who apparently thought dropping the pins through the holes on the top great fun, lol. I removed all the pins and used canned air to clean out all the dust bunnies, put it back together and was back in business in about an hour. The machine sounds great and doesn't skip a stitch!
Oct 13, 2008 | Brother Sewing Machines
Bobbin tangles on Brother xr 65
This was happening to me too, I reversed the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
May 19, 2008 | Brother XR-65t Mechanical Sewing Machine
Brother XL-3510 Mechanical Sewing Machine Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
