SOURCE: HDD not recognised
HI Your Hard Drive is previously formatted and have done different partition provided by your previous machine where you took this hard drive from. Use "The Partition Magic" Software, it will help you to fix and repartition your hard drive in the new format. I have this problem before and now my hard drive can connect with any computer. The key in this issue is any hard drive goes with the original machine has been formatted and do its own partition from manufacturer so if you take it out later for use with other machine, you will need a software to completely rearrange the new partition in universal format so other computers can recognize it. This manufacturer purpose to protect your data from hacking, stealing once you take it out from the original machine. That is why when you connect it to other machine, this hard drive will not be recognized. I has this partition magic software and can make you a copy so you don't have to buy it. Just read the instruction and you can fix it for both 2.5" and 3.5" HD. Please email me at [email protected] and provide me your mailing address, I can send the copy software to you. Regards, pingping
SOURCE: hard disk acess problem
Hi, What the message mean is that Windows can not read/understand the filing system (something like the Table of Contents in a book) and therefore do not which and where are your files in the 80Gb. A few things you can try: 1. Run Windows Scandisdk on the Hitachi 80Gb; 2. Run any third party disk check/utility such Norton Disk Doctor. Alternately, you can use a file recovery software (such as GetDataBack) to recover/copy all your important files from the 80Gb and transfer them to another mass storage device. Thereafter, you can re-partition and re-format the said Hitachi to start new/fresh/clean. Hope this be of some help/idea. Post back how things turnes up or should you need further information. Good luck and kind regards.
SOURCE: Hitachi 500 GB sata Hard Drive
i have just format my compter now im haveing problums geting my sata hard drive back in i have the floppy disc what came whith it not shore how to install it
SOURCE: hi, my external hard drive recently cannot be
Hi there
I dont know if this will work for you but looking on the web I came accross someone who had a similar problem they fixed it as follows.
They installed Tweak UI and then
She was able to get the drive recognized using "Tweak UI", clicking on My Computer, Drives,and check marking Drive F. It did the trick.
Hope this helps software link for you
http://www.annoyances.org/exec/show/tweakui
SOURCE: My disk drive does not
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
