Question about Dryers
My GE electric Harmony dryer will dry a few loads of clothes, then stops heating or only provides very low heat. No clogs in the vent, filter is not clogged. Of course when the tech came it heated right up, because it had sat all night and had no clothes in it. I use no fabric softener.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Hello, I'm having problems with my dryer. I have a GE Profile Harmony Dryer and its not drying like it should, I have to run the cycle 4 or 5 times for it to get hot and dry the clothes... It also has...
The first thing to do is ensure that the outlet air vent is not clogged with lint, socks, or other obstructions. It may be clogged at a point outside the dryer, so you might have to move the dryer out of the way, then use a flashlight and mirror to look into the vent.
If it is not clogged, then the problem is likely the heating element or heat sensor.
Jul 13, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My GE Profile Harmony dryer won't dry. The drum is turning but the clothes just won't dry. Circuit breaker is not tripped.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct.
Dec 01, 2010 | GE Profile Harmony DPGT750EC Electric...
Heat is on clothes are not drying
The air flow through the exhaust is blocked/clogged.
This usually happens at the vent where it exits the house, but can also be where the dryer connects to the vent in the floor/wall, and also occurs throughout the entire pipe length.
Make sure the inlet, pipe, and outlet are cleared. make sure the lint filter and surrounding area is clear.
You should hjave a good strong air flow comming out of the vent on the exterior.
(Improper airflow prevents the moisture from exiting the dryer.)
Oct 03, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony dryer
You most likely have a clogged venting system going to the oustside.. Try this pull the dryer away from the wall remove the flex venting pipe.
Run a load now yes i know the heat and moisture will come in the house but it is just one load(open a window) if it works ok then you will need to get someone out to clean your vent and your money back from the repairman who came out .....any technician worth anything should have told you this.....98% of long dry time calls are a plugged venting..just and FYI...Hope this fix ya if so plz rate
Jan 26, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
29 people viewed this question
Top Dryers Experts
