Question about Philips Televison & Video
I have Philips Magnavox 51MP6200D-37, and when I got it, I plugged it in and set up my remote and all of my inputs and everything worked great. I left it on halfway through the night, waking up in the middle of my sleep and hit the "all off" button on my remote...turning everything off including the TV. When I woke up, I pushed the "all on/off" button then to turn everything back on. I then noticed that the power light was blinking. It will not stop blinking. I have tried changing the fuse on the circuit board. I have tried leaving it unplugged for 5 hours, then replugging it directly into the wall and turning it on, only to find the light to continue blinking. I have held the power button in for a minute, (because I read this somewhere) and it did nothing. I am really upset because I just bought this TV off of a guy that I think really screwed me. I am praying that someone can tell me what part I need to get as I am electrically talented with soldering or circuitry. Please, if someone can help me get back to me as soon as possible. Thank you.
bluenadas
  • 203 Answers
SOURCE: Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Posted on Jun 08, 2007
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Slinteriors
  • 8617 Answers
SOURCE: My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Posted on Jan 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Apr 03, 2009
Power light wont come on a magnavox flat screen tv
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 23, 2012 | Philips Magnavox 42MF521D/37 Television
Magnavox 51MP6200D/37
The conversion board needs replaced.
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
My 51pp9100d/37 philips TV doesn't have any sound.
This set has a "small signal board" The board is about 3x5 inches and plugs into board on far left as seen from back of set.
A lot of these fail:
low sound
no sound
intermittant sound
no remote functions
no channel up or down
etc etc
Last time I looked board was around 100 exchange rebuilt
Mar 13, 2012 | Philips Televison & Video
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I have a Magnavox 51MP6200D/37 television and had a technician diagnose the flyback as being bad. I've been trying to find one online, but can't seem to find the part#. Anyone happen to know what it is?
Part number is:
312226832951
It is marked as no longer available from Magnavox(Philips) but you may be able to find one on the internet
SD TECH
Sep 29, 2009 | Televison & Video
Need Universal remote code for Magnavox 15MF400T/37
these are the codes associated with Radio Shack's line of remotes:
One for All Universal (Radio Shack)
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
And I was also able to find these:
UNIVERSAL REMOTE CONTROL CODE LIST for TVs
MAGNAVOX
002 009 109 118 209 309 402 408 502 508 510 807 914 917
Jan 24, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
MAGNAVOX 51MP6200D/37
You will have to give the set out for service. This is not something you can service yourself.
This can be some failed components in the CRT bias and drive circuits, or maybe a CRT has failed. This has to be determined by taking measurements and doing some tests.
I believe that your set may have been manufactured by Philips.
Philips Support:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=51MP6200D%2F37&session=20080214101141_66.249.66.131&slg=ENG
Jerry G.
Apr 16, 2008 | Philips Magnavox 27MS343S 27" TV
51'' magnavox 51mp6200d/37
It's 1020i, if you haven't gotten the info somewhere else already
Oct 28, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
