Question about Troy Bilt Tb70ss Gas Trimmer
I can't load new string help - Troy Bilt Tb70ss Gas Trimmer
Black & decker LST201 direction loading the string weed eater
when you are holding the spool on which you wind the string wind the string on in a anticlockwise direction
if it uses 2 strings ( one out of each side of the spool
wind in both strings together in the anticlockwise direction
that way , when you put the spool in the head and go to use it , the string is wound the right way to feed out and not get tangled
Sep 10, 2016 | Sewing Machines
I have a smith corona electra 220 and the space bar does not advance the paper tot the next spot. everything else works. took the back cover off,a nd found a loose string coming from a black spool. can you...
That is what we call the draw string, there is a spring loaded pull that this string is. Wound around. The pulley has to be wound up and. Then the string fits in a. Little slot. Somme times the spring breaks in the pulley, the string fits in a slot by .a knot which sometimes breaks, sorry about the bad news, the string is fishing line and wears out as it gets old.
Jan 28, 2014 | Office Equipment & Supplies
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
Please describe your issue or question (*) Last year we bought four of the Gemmy Color Chasing Light Show strings with the multi-color LED tear-drop shaped bulbs (#0293751). All four strings worked...
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
Dec 07, 2009 | Gemmy Toys
Pull string came off as I was trying to start it.
there should be three or four screws to the top of the mower where the string goes, after purchasing new pull string make sure you wind the spring when you re string, so that when you put the cover back on it will be spring loaded and in proper working condition
Oct 17, 2009 | Ariens Garden
String won't stop advancing and tangles around the unit
Hi
I would guess that your spring has got lost when you reloaded the string .
check and see if it exists if not put in new one .
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
I am an MCA student.To read the file from PC to handheld device
you might need to run a anti-virus through your computer. it might have a bug. :) hope this helps!!
May 20, 2009 | Microsoft Windows XP Professional
Can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
May 17, 2009 | Craftsman Garden
Can't load spool
If you have the model number on unit go to blackanddecker.com and you can view or load manuals there. Click on customer support and then under "products and services" you'll see "part and manuals"
Hope that helps...
Mar 22, 2009 | Black & Decker String Trimmer Cordless 12"...
Troy Bilt Tb70ss Gas Trimmer Logo
273 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
