Question about E-Machines eMachines Desktop PC
No sound on my computer
Recently my oldest granddaughter did something to our computer. she turned off the volume to our speakers, it also says that we have no mixers? can anyone help me out on this problem? thank you deb rose
  • 48 Answers
If you are using windows then double click on speaker icon in system tray near TIME display.. it will open a window, now see if there is a check box marked as MUTE or volume level set to low (in Master Volume & Wave ).. Un-check if mute is selected or level up the volume slider... if there is no icon then use control panel to go for sound settings.. if it say No Device then use your computer driver CD and install sound driver and restart your PC... please inform if it does work.
Plese Rate Me.. Thanks.
Posted on May 13, 2008
Hi the sound in my speakers is reallllly low and i can't turn it up with the volume button like i used to, is there a wire missing or something ?? really annoying.. :S
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 15, 2011 | Koss HDM 11 Computer Speakers
I have a set of SUN-115H speakers that has a volume problem. When testing with DXDIAG, you can hear the sound but it is very faint even with the volume knob turned to full. Any ideas? ? ?
Is the power to the speakers correct? Since these are computer speakers,have you checked that the volume on the computer is turned up all the way? Have you tried the speakers on another computer or portable radio of something?
May 06, 2011 | Sun -115H Computer Speakers
When i skype with my granddaughter, i can hear her, but she cant hear me
It must be with your mic or with your computer's sound settings or with your skype sound settings. First check your Microphone, you can record something using the Windows (if your o.s. is windows xp or vista, or etc..etc..) built-in Sound Recorder.
Open your computer's sound settings and make sure it's default recording device is Microphone and the volume is turned up.
Open the skype, click "Tools", then "Options" and again click" "Audio Settings" and check the mic volume, if possible uncheck the "Automatically adjust the microphone settings" and turn the slider to the right. Save the changes you've made and try again.
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Skype IM
Can't control sound
what you need to do is the audio you must plugged it in thegreen spot in the back of the pc
Aug 05, 2009 | Dell 5650 Computer Speakers
Speakers have low sound
Look into your computer audio setup, usually a icon in the lower right. they have controls for volume, some have different areas such as oper sounds, outdorrs, etc. Maybe these are turned down or muted...Also plug a head set into the CD or DVD rom port in the front if yu have and see if the volume is good. Possible bad audio card. Also try different speakers. Small speakers sell for $20.00 or less.
Jul 08, 2008 | Logitech Z-5300E (970102-1403) Computer...
No Volume to speakers
I rebooted my computer and reinstalled windows now my speakers dont work.How do I get them to work?
Jun 12, 2008 | Audio Players & Recorders
Speakers wont turn down
its the audio quality in windows settings. go to the cpanel and change the sound volume in windows sound settings
then change volume. it should work otherwise. there old speakers. try buying a new bose speaker or something.
Jun 01, 2008 | Audio Players & Recorders
No sound
To troubleshoot a no sound issue first you must check your device manager to make sure the audio device is installed properly.
To goto the device manager in XP:
Right click my computer>Properties > Hardware Tab > Device manager.
Look for your audio device in the list under "Sound, Video and game controllers". If it has a exclamation mark or question mark beside it you will need to download the most recent drivers from the manufacturer's website.
Next step is to goto
start>programs>accessories>entertainment>volume control
make sure that Wave nor Master Volume is not muted, and both are turned up.
Third step is to check for onboard volume control, there might be volume controls on the system hardware itself.
If you say that external speakers work and not the built in speakers, then the headphone jack that you plug the speakers into may be defective. As it is always detecting something plugged into it and never turns the internal speakers on.
Mar 24, 2008 | Computers & Internet
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Computer speakers make a fuzzy sound
Hello there
Yes, Niera, you have to update, the sound drivers, and see on BIOS if something is disable on sound. other than that is posible a a speaker problem.
Jan 13, 2008 | Audio Players & Recorders
E-Machines eMachines Desktop PC Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
