Question about Brother IntelliFAX 4100 Laser Fax
Says Printing & Online Stuck
The LCD reads Printing & Online, system stuck. If I unplug and then plug back in it will print the faxes received, then stays in print mode. Can't fax oot or print reports (says, printer busy) Is there a wat to reset?
  • 1 more comment
  • Anonymous Dec 29, 2008
    How do you fix this problem
  • rrackett Jan 13, 2009
    Having the same problem too. HELP!!!!!
  • rrackett May 11, 2010
    Razors,
    Thanks that did it!!! I just had to re-set the time and date but that was not a problem.
    Thanks again!
  • 215 Answers
When this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
Posted on Jan 29, 2009
I think my printer is stuck in fax mode how to i start printing again
Leave it unplugged for a night and replug the maching. Go through the setup menu again and just try copying something. This should clear the fax buffer. Then retry the fax.
Oct 07, 2014 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
Display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Feb 11, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax not printing
Where can I find the solution?
Jun 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Won't receive or send
Try hitting Menu * 2864 (it should say maintenance) then 91 then 99
This will reset the fax machine without erasing your settings. It should clear it up. If it doesn't work after a few tries, you have to hit 0 instead of 91 and that will reset the entire fax machine to factory defaults.
Feb 20, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Jan 28, 2008 | Brother MFC-8220 Fax
Brother Fax 8360p Stuck in Printing
TURN MACHINE OFF HOLD DOWN STOP KEY AND THEN TURN ON OR PLUG IN ...worked for me
Nov 28, 2007 | Brother Office Equipment & Supplies
Printing problem
Sounds bad, possible main pcb fault, try reset by.  menu * 2864 real quick then 99 set or start.
Oct 21, 2007 | Brother MFC-620CN All-In-One InkJet...
PRINTING ONLINE
Unplug the power cord from the back of the machine for 30 seconds. Put your finger on the stop key first and then re plug the machine, hold the stop key until the time and date return to the LCD. Do not worry about losing any faxes the machine can be powered off up to four days without losing faxes in memory.
Sep 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Printer not printing
Try unplugging it or pulling the power brick out of the back, wait a few seconds, plug it back in, and then turn it on. It might have something stuck in its memory.
Aug 21, 2007 | Lexmark Z1420 InkJet Photo Printer
Brother IntelliFAX 4100 Laser Fax Logo
293 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
