Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire 400 41742990 front loader, won't start. Worked fine last time I used it, door and drawer are closed tightly, outlet is hot, no breaker problems.
    Brigadier General:
  • 3,917 Answers
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
How do I runa diagnostic on a Frigidaire Model 41744152400
most front loader washers will wash fine all the time, however there is a pin switch on the front that the door strikes when closed make sure the door is closed and locked .
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader will not turn on
Hello - Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Sep 24, 2012 | Frigidaire ATF6000ES Front Load Washer
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Machine will not start, replaced start switch now machine starts with the hot and warm button i think i have got my wires crossed
the start switch will just have a hot wire,, with a momentary closing when you push the start switch,, if you list the make and model of your machine, I'll try and find the wiring sequence for you
Jun 30, 2011 | Dryers
My ftf530fs has worked every time I've used it, but tonight when I closed the door it would not start. The door lock light is on, but it will not start on any setting. What do I need to do?
My GE front loader did this. I unplugged/plugged it in and it started. Weird, but I hope your solution is that simple. Also, check your breaker.
Nov 15, 2009 | Frigidaire FTF530FS Front Load Washer
My Frigidaire Affinity front loader smells like mold
have you cleaned the main waste pipe as this surpisingly enough gathers a lot of gunk and in warm weather makes it smell,i say this cus we expeirieced this and i replaced rather than cleaned the waste pipe,worth a try it worked for me,rgds paul
Jul 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Won't start
We have a kenmore 27182 that has a very bad wabble in the spin mode. any suggestions?
Dec 22, 2008 | Kenmore 27182
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
56 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
