Question about Panasonic Televison & Video
The Panasonic dmr ez28k DV input will play video from a camcorder, but when trying to record you get an error message saying it can't record and make sure camcoder is connected and playing video. It is connected and playing video. So what is up with this.
I'm having the same problem. Is there a solution? Thank you.
Posted on Dec 08, 2010
I have the Panasonic DMR EZ28K and while in stand by mode and even while playing a DVD, the display will show U99. When this happens, the unit will not turn on to record whatever I have programmed. To...
You can probably fix this issue by updating the firmware and doing a system reset. First, download the latest firmware and burn it to a CD. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ28K.D#ts
Now, power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this. This will install the new firmware and re-initialize the system settings.
The complete manual is here: http://service.us.panasonic.com/OPERMANPDF/DMREZ28-MUL.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Panasonic DMR-EZ28K DVD Recorder
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Panasonic DMR-EZ28 and DMR EZ27 both freeze up every other day.
I have the panasonic DMR EZ 28 for 4 months. I have beendownloading home videos from my camcorder through the IN 2 port without difficulty until yesterday; Now, when I attach my camcorder through the IN 2 port, I can hear the video, BUT not see by video on the TV monitor; I reconnected the camcorder through the IN 1 port in the back of the DMR and it works, but it's a pain to be working in the back of the machine. Why aren't I seeing the video (but hearing it) when connecting to the IN2. Faulty connection??? Did I program something wrong???
Dec 13, 2008 | Panasonic DMR-EZ28K DVD Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Error message "push the reset switch"
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
Aug 10, 2008 | Panasonic PV-GS300 Mini DV Digital...
Can not get the camcorder to play on computer
more details needed.
-what is the model of your DVD recorder - did you select the DV input? perhaps that model has a DV connection proprietary to it's own camcorders. Panasonic does this on many models of their DVD recorders.
-on the computer, how are you attempting to access the camera once connected?
Mar 06, 2008 | Panasonic NV-GS30 Mini DV Digital...
Problem with Panasonic NV-GS3 camcorder
use cleaning cassette , before a brand new blank tape ( may have a worn or damaged tape in your library ) ;
Jul 29, 2007 | Panasonic NV-GS17 Mini DV Digital...
Televison & Video Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
