Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
It does not open. Please advise The cloths are all wet inside and the door is locked and machine will not start again
  • 1 more comment
  • patcan May 14, 2008
    do not see or feel it , even removed the soap tray is there any thing I have to remove
    Hve unpluged overnight still does not work it is a model #mah9700aww
  • patcan May 15, 2008
    no cord
  • 796 Answers
The sensor is not working properly
Posted on May 13, 2008
  • isaac johny
    isaac johny May 13, 2008
    call a technician...and replace the sensor
    Genius:
  • 3,422 Answers
NOTE:Unplug it first..
If you open the detergent dispenser and feel along the front edge behind the removable cup there is a coloured cord usually red or green in colour this in an emergency door release, by pulling on it firmly the door will unlock.
Goodluck..
  • 2 more comments
  • Priya darshan May 13, 2008
    Please don't forget to rate or accept the solution as fixya
  • Priya darshan May 14, 2008
    HI,
    Just a few questions:
    Does washer has power and is door lock light on?Just leave it unplugged for an hour and then try again.
    pull out the dispenser drawer push down on the tab remove the drawer
    and there is a cord you can pull to unlock the door pull on the door
    same time you pull the cord.
    I hope im clear,
    Please don't forget to rate or accept the solution as fixya.
  • Priya darshan May 15, 2008
    ok oes washer has power and is door lock light on?
2 Suggested Answers
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Try these steps:
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My washing machine is Neptune. The front door is locked and water is inside with wet clothes.
If you have a Maytag Neptune MAH3000, MAH4000, MAH5500A or a 2000 stacker then your wax motor might be the issue. See www.neptunehelp.com for info on the faulty door latch wax motor and how to fix it.
If unplugging machine does not allow the door to open then remove the 4 philips screws on the soap dispenser bezel ( under lid) and remove it. There should be a colored plastic cord in there you can pull on to unlock the door, It is an emergency pull cord.
May 17, 2009 | Washing Machines
MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer won't unlock. I may have to replace the wax motor per so many other blogs. I may be able to get to it in two days. Meanwhile, I have expensive clothes locked inside my...
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag front end loading washer is stuck locked
Open the detergen/bleach diospenser cover and there is a tab there that you can pull to open the door. You will likely need to replace the wax motor and control board.
Apr 07, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
592 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
