Question about Ovens
Need an manual for a westinghouse DSK963S NG duel fuel Cooker
Need Westinghouse gas wall oven AWGB700FP manual
Request the manual directly from Westinghouse.
Jul 20, 2014 | Ovens
Can anyone provide the correct wiring instructions for a replacement oven 6 button timer (C00224982)unit for a Cannon Harmony Duel Fuel Cooker. Old unit has 4 terminals, new one has 6. No instructions were...
Hi, I would contact your supplier, it could be that they have supplied the wrong unit or that it has been modified since original manufacture, these things sometimes require links but normally all the kit required is in the box along with instructions.
If the unit is correct the supplier should be able to tell you what the connections are in relation to the existing unit. Hope this helps.
May 23, 2014 | Ovens
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
I have Terim Duel Fuel range cooker which at the moment can only be used by bottle gas/calor gas and not mains gas. Is there anyway it can be adapted to be used for mains gas?
you have to change the jets to the "mains" gas, usually these are found inside the back cover of the oven, sometimes it is only a wrench adjustment on the gas valves theselves.. look in your manual on how to do this, and if you don't have the manual, you will need to order it from the terim company
Mar 11, 2011 | Ovens
Bought new cooker however no user guide its a kenwood ck404 duel fuel double oven 5 ring burner. need to know what symbols on switches are and what they do.
I have a problem with my Kenwood CK404. When I put either oven on (it's a double oven), once it gets hot it starts to make an awful noise. At first I thought it was the fan in the main oven. But it makes the same noise in the small oven, which doesn't have one. Does anyone have any suggestions of what the problem could be? Kind Regards
Trotwood
Aug 21, 2010 | Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
The markings for the controls on my Delonghi DFS090Do duel fuel cooker have worn off.Can I get an original picture of the control markings to re apply them myself?
I have the same problem. How did you do it? Did you write them yourself on the metal? Did you buy them?
Thank you.
Jorge
Oct 03, 2009 | DeLonghi Ovens
No power in oven
If it has a digital or anologue timer, make sure it is set on manual, or the oven will not work.
Dec 05, 2008 | Ovens
110v Range cords
Most duel fuel ranges need 220 volts. and the outlets are different.
If you can't find a heavy standard real range cord it is because in your area they probably changed the code. Try ordering out of state from Home Depot E bay etc. Or change the outlet.
Jun 16, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
