Question about Water Heaters
I have a Kenmore water heater model number 153339461. Tried to light per instructions and pilot still is not lighting. What else should I do?
  • 377 Answers
If the pilot is not lighting, you may have a lot of air in the gas line. If the pilot light is not staying lit, you may have to change the thermocouple.
Posted on Sep 07, 2010
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
After years of problem free hot water the pilot light went out and now when trying to re-light the pilot light as per instructions it does not light although the spark is strong and hitting the ther
look at label on side of unit, then add a comment with Brand and type of gas water heater.
AO Smith tank-type, or Rheem tankless so expert can suggest best solution.
Tank-type:
Gas control could be bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Water heater is in lockout because combustion chamber overheated and tripped FV system because air intake is clogged.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 10, 2012 | Water Heaters
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
Jul 26, 2012 | Water Heaters
I have a Rheem21vp50e1a hot water heater. the vent is running continuously but the pilot is not on. Turned it off to reset and it will still not run. The house has gas so what could be the problem.
More information is needed to give accurate do-it-yourself help.
Have you changed the thermocouple?
http://waterheatertimer.org/pdf/How-to-replace-thermocouple.pdf
http://www.youtube.com/watch?v=v0aBPsNg6vo
Some model numbers do not have a standing pilot light.
What do the re-light instructions show on side of unit next to gas valve? What does your manual say?
What type of gas control valve does unit have. Is this electronic gas control valve?
Add a comment with information.
Open following links for READING about general pilot light problems across different types and models of water heater: do-it-yourselfer will find useful resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Standing-pilot-light-maintenance.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 02, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
Aug 24, 2011 | Noritz Water Heaters
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
124 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
