Question about Casio FX-115ES Scientific Calculator
Exponents - Casio FX-115ES Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To enter decimal exponents, use the x10^x key below the 3, followed by the exponent. For example, to enter one million, press 1 x x10^x 6 and see 1000000 (actually, the leading one is optional: if you press x10^x without a value, the calculator will supply a 1).
To raise a value to a number, use the x^ key above the sin, followed by the exponent. For example, to calculate 2^3, press 2 x^ 3 = and see 8.
Posted on Sep 07, 2010
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
Jan 26, 2016 | Casio ClassPad 300 Calculator
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
How to use it for exponents?
To enter exponents (1, 2, 3, -3..) use the general power key marked with Y^x or X^y or ^. Enter the base press the general power key then the exponent. If exponent is negative try enclosing it in parentheses. use the change sign key (-) to enter the negative sign before the exponent.
To enter power of 10, you can use the shortcut key marked Exp (the 10 must not appear when the Exp is used to enter exponents for power of 10).
Feb 24, 2013 | Sharp Office Equipment & Supplies
Decimal exponents don't work
The EE (or x10^x on Casios) does give a syntax error if you use it with decimal exponents, but the expressions do calculate correctly if you use the full expression with the general power key. The EE key is a shortcut and may have been designed to accept only integer values for the exponents.
I tried that on Casio and the TI calculators.
May 08, 2012 | Texas Instruments TI-84 Plus Silver...
Write with positive exponents
To rewrite an expression with positive exponents, you must use the identities
1/a^n=a^(-n) and 1/a^(-n)=a^n
Example: a^(-3)=1/(a^3)
1/(a^(-4))=a^(-(-4))=a^4
To convert a whole expression, you scan it for negative exponents and start changing them one a time, until you get only positive exponents.
Depending on the expresiion you are dealing with you may have to use other rules, such as (a^n)^m= a^(n*m)
Mar 30, 2012 | Office Equipment & Supplies
How do I do exponents on this calculator?
Two keys can be used to enter negative exponents on the TI-30Xa scientific calculator; the [y^x] key or the [EE] key. The [y^x] key is used for all exponents while the [EE] key is used for scientific notation only.
The examples below will demonstrate how to use both keys:
1) Entering 7^-2.
• Press [7] [y^x] [2] [+/-] [=].
• The calculator will display: 0.20408163.
2) 1*10^-3.
• Press [1] [EE] [3] [+/-] [=].
• The calculator will display: 0.001
Sep 18, 2011 | Texas Instruments TI-30XA Calculator
How would you do negative exponents for scientific notation? example: (6.0 x 10^6)(2.0 x 10^4), I am required to use the EE button for my exponents since it's a scientific notation equation but I do not...
Use the (-) key for negative numbers (not just exponents) instead of the - key. The - is to subtract one value from another, (-) is to input a negative value.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
Adding Exponents on a Casio fx-300MS
The calculator applies the rules during the internal calculations. But all it shows you is the (final) result. It does not keep track of what exponents you used to get to the result. It is not capable of doing symbolic manipulations.
Hope you are not too disappointed.
Apr 22, 2009 | Casio FX-300MS Calculator
Entering a problem
Hi Loringh,
see, high exponents are +ve powers, while low exponents are -ve powers.
e.g. for 1200000=1.2X10^6=1.2E+6 (high exponents)
for 0.0000000012=1.2X10^-9=1.2E-9 (low exponents)
I think so easy ?
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Dec 12, 2008 | SoftMath Algebrator - Algebra Homework...
Exponents
the Xy button, 10 Xy 2 = 100 (10 x 10)
to do a neg exp you have two options, one use brackets if calculator has them.....
10 Xy (-2) = 0.01
or two inverse your number, ie: make 10 into 1/10th, use fraction entry on calculator.
1/10 Xy 2 = 10 Xy (-2) = 0.01
May 31, 2008 | Casio FX-300MS Calculator
Casio FX-115ES Scientific Calculator Logo
260 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
