Question about Mtd 19 In. 173 CC OHV 3-In-1
The engine is locked up and has a hole in the block. Where can I get a replacement engine? It wouldn't bother me to get a Honda or Briggs just as long as I can bolt it on the deck.
  • 472 Answers
I have them send me a email to mowershop@live.com i will need some numbers and ill price ya one
Posted on Sep 07, 2010
I need valve spec,s for mod PM0435001,
For specs on the engine, look for engine model number and type then google. You will find the engine model number either on the block of the engine or on the fan cover. If you can't find a number, google the brand of the engine using search key " engine model number location" ex Briggs model number location. Could be either briggs, tech, honda or other. Good luck.
May 22, 2013 | Coleman Powermate Electric Generator...
What parts do I need to install an electric start on a 12.5 hp briggs logsplitter
first you will need to make sure that the block will accept the starter by that i mean are there holes tapped into the block for it if so replace flywheel to if it is not set up for a starter it should have "teeth along the bottom of flywheel for the starter to engage in then add a solenoid battery and starter switch and you should be ready
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Timing marks hyundai excell
What year, and what engine?
If it broke I wouldn't bother replacing it until I confirmed that the valves are NOT bent! Usually when the belt brakes on a Hyundai the piston will hit a valve or two and sometimes the valve will actually poke a hole in the piston.
Feb 18, 2012 | Cars & Trucks
Chevy 350 '85 a small piece of sealer fell into oil pressure hole where would it move to when engine is started towards the distubtor and into the oil pan or travel to and restrict oil supply to...
Likely it would move back towards the pressure sending unit and possibly block it off. Why not just disable the distributor and crank the engine over a couple of turns with a rag over the opening so oil doesn't go everywhere? That should push whatever you dropped into the hole right out of there!!
If the piece that dropped into the hole was silicone, depending on how large it is, it could give you a problem, depending on where it lodged. A very small piece probably wouldn't matter, as the oil passages are fairly large. If the stuff that went in the hole was teflon tape from the sender, I wouldn't worry about it at all.
Jul 03, 2011 | Chevrolet Blazer Cars & Trucks
I have a 5.5 OHV Briggs & Stratton and it only runs good when it almost fully choked or half choked. There is one adjustment screw on the carb., but when I adjust it , it does not seem to run any...
The carburetor needs to be cleaned. There is something in one of the passages that is keeping it from running correctly. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal. I hope this helps you out.
Apr 06, 2011 | Briggs & Stratton Briggs Stratton...
Can i install electric starter on 10hp briggs & stratton ?\r\n Thanks !
Easy to check if your engine was designed for additon of starter. Starter motor is mounted at rear of engine to gain access or flywheel. The block would need to have mounting holes already drilled into block and the flywheel will need to have ring gear. There should be a removable plate on fan cover (or cutout) to allow starter to enter flywheel. If your block has mounting holes but not the geared flywheel, you could try to find a dead motor with good starter parts at small engine shop. Good luck
Sep 11, 2010 | Electrical Supplies
Does briggs and stratton make the engine for dewalt pressure washers
If it is a DPH it has a Honda engine. If it is a DPD it has a Dewalt engine that is made by either Honda or is a Chinese copy of the Honda engine. I looked at a photo of the engine and it looks like a Honda engine not a Briggs engine. Look on the engine data plate and if it says Made In China it is a chinese copy. If it say's Made In Japan it is a Honda. Some Briggs engines are made in China also so it is hard to tell except by the looks of the engine. The Chinese copy of the Honda engine looks exactly like a Honda.
Jan 10, 2010 | Dewalt 3800 PSI Pressure Washer
Gas leaking into crankcase in Briggs Stratton 17 1/2 hp engine-
Hi
If it has a steel seat i would not bother with the seat if it has a rubber seat i would replace. To install rubber seat you just need a punch or anything that fits in the hole with a flat bottom.
Sam
Jan 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas line vapor locks on pressure side of fuel pump intec v twin 20 hp
Sounds like you have a hole in the fuelpump diaphram which is pumping air into the line or could be a hole in the line or loose line.
Aug 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mtd 19 In. 173 CC OHV 3-In-1 Logo
71 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
