FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
Not finishing wash cycle (by 2 users)
posted by imjrm on May 13, 2008
The machine seems to work normal until about 9 is left on the LED then just stops and displays zero. Leaves visible water in machine and clothes soaked. I had a technician look at it. He replaced the door latch switch which lasted about two weeks. Now another technician is telling me to replace the computer.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dinogenovese, posted on Jun 12, 2008
We have the same washer & drier Maytag Neptune during the wash cycle it goes to 9 then to 7 an d 0, stops & theres always some water left inside the washer leavin the clthes soaked, the drier has to work 3 times as hard to dyr the clothes. Could some tell us how to fix this problem, or should I thrash them & go to Whirpool washer & drier??????
Best Solution
posted on May 24, 2008
FixYa! (100)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 289 votes
you have a clogged water pump,thats  why water is left behind
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bearing
Sounds like a bearing going... Answer This...
not spinning, not drying
washer is not drying Washer... Answer This...
MAH8700AWW
We were washing a load and the... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
